M32R
Wed Jan 02, 2008 2:29 pm
by Marmes
Hello!
Does anyone have some tools for M32R processors?
Thanks!
Tue Jan 22, 2008 7:52 pm
by wmcdonal
Yes, what exactly are you looking for ?
Wed Jan 23, 2008 2:44 pm
by salex
Renesas has a tool for flashing the evaluation boards containing it.
It is called M3S-UFLA32R, but it is only able to flash - not read.
Any other ideas?
Wed Jan 23, 2008 2:48 pm
by Marmes
After reading some datasheets, It seems that everything to be able to read the flash is there explained,doesn't seem to be very hard.
It even says that the only protection this processor has is a pin pulled to to a state Low to prevent the ecu to be read or written, I know there are other kind of protections ,the ones used by some companies here to protect their work where they set an ID.
What we need is a simple iso 9141 interface with some dc to dc converter to pull the voltage up to disable the protection.
But this is me guessing.
Cheers!
Sun Jan 27, 2008 9:16 am
by salex
The manuals seem very interesting. I wonder what sort of interface we might be able to build following the instructions!
Wed Jan 30, 2008 9:38 am
by Marmes
I think what it's needed is to put the FP in High state to put processor in boot mode and read.
This is me guessing again :S
Wed Jan 30, 2008 1:02 pm
by salex
Marmes wrote:I think what it's needed is to put the FP in High state to put processor in boot mode and read.
That is the main idea, but it will take more than the instructions in the manual to be able to read. Boot mode supports writing in this one
Wed Jan 30, 2008 1:52 pm
by Marmes
What can we do to read it?, can we use the tactrix cable for mistubishi?
Is the MR32 this ones?
Sun Feb 03, 2008 2:05 am
by christian_piasini
Hello, it is the MR32 the mcu you see in the picture below?
Regards
Sun Feb 03, 2008 5:53 am
by Marmes
yes it is.
you think its not?
Then explain yourself
Best Regards!
I think is...
Fri Feb 08, 2008 9:37 am
Yes it is, I joke ....
some times as well has to joke a little bit.....
Regards
Fri Feb 08, 2008 11:08 am
by Marmes
that one has a jtag port, i think it is...
I don't need the Jtag port
Fri Feb 08, 2008 2:08 pm
With this ecu we don't need to read it trough the JTAG....
we do it trough the ecu plug, without open it...
Regards
