07 STi
07 STi
Postby Garage Tuning » Tue Sep 12, 2006 3:32 pm
Any support yet? It has the air pumps like the WRX, but 06 WRX software will not talk with it.
ERROR READS:
It does ssm2_init 10 times then
kernel get version
validating denso kernel ram area addr: FFFF0000 Len:0008[/quote]
Garage Tuning
Re: 07 STi
Postby Jon [in CT] » Tue Sep 12, 2006 3:51 pm
Garage Tuning wrote:... but 06 WRX software will not talk with it.
Can you be more specific about the software involved and the error message(s) logged?
Postby Garage Tuning » Tue Sep 12, 2006 5:02 pm
I don't recall the message. We'll try again and copy the error.
Garage Tuning
Postby Garage Tuning » Fri Sep 15, 2006 5:59 pm
Got it
kernel get version
Garage Tuning
Postby Jon [in CT] » Sat Sep 16, 2006 11:24 am
Are you able to log ECU data using ecuExplorer? You can download it for free at http://www.tari.co.za/cgi-bin/yabb2/YaBB.pl. Which cable do you have?
It's possible that a 2007 Impreza does all communication over the OBD-II datalink connector via CAN (controller area network) protocol. If so, you are SOL.
Subaru TSB 11-73-05.
Postby Garage Tuning » Sat Sep 16, 2006 3:04 pm
I;m using the DBW cable
using the tari racing software i got this message
1452 byte kernel read.
!! PROCESS ABORTED !!
Garage Tuning
Postby Tea cups » Sat Sep 16, 2006 3:18 pm
Tari software won't read DBW cars. You need Ecuflash.
Tea cups
Postby Garage Tuning » Sat Sep 16, 2006 4:52 pm
Bah! Well I was using ECUflash first and was getting the error in the first post.
Garage Tuning
Postby Spiider » Sun Sep 17, 2006 6:29 am
2007 = CANBus?
Postby Jon [in CT] » Sun Sep 17, 2006 6:29 am
I guess I wasn't clear when I wrote earlier: "Are you able to log ECU data using ecuExplorer?" Are you able to log data like RPM and MAP with ecuExplorer?
And both cables support DBW Subarus - which one are you using?
Postby Garage Tuning » Mon Sep 18, 2006 11:55 am
Jon [in CT] wrote:I guess I wasn't clear when I wrote earlier: "Are you able to log ECU data using ecuExplorer?" Are you able to log data like RPM and MAP with ecuExplorer?
I couldn't get it to connect to that software at all. I am using the most current cable.
Garage Tuning
Postby radsdau » Mon Sep 18, 2006 3:51 pm
Spiider wrote:2007 = CANBus?
That's what I'm thinking.
Postby Garage Tuning » Mon Sep 18, 2006 6:24 pm
Does this mean I'm hosed? I need to turn off the stupid smog pump.
Garage Tuning
Postby radsdau » Wed Sep 20, 2006 4:45 pm
Probably, unless someone like Cobb or EcuTek support later model (CAN based) vehicles, which they may well do.
Postby Keener2.5 » Tue Oct 10, 2006 7:45 pm
Hi. I work for Garage Tuning, and I am the guy with the unkown ECU Motor in my GC. What I got from the supplier is that it is preproduction 07-08.
We connected to an 07 Vlimited STi without any trouble tonight. Here is the log, can anyone tell me anything about it? I still am not able to get into my *supposedly 07* ECU.
Thanks for all your help
-Brian
[04:56:20.413] Version 1.28.716
[04:56:20.423] 8 memory models read.
[04:56:20.673] 73 ROM metadata models read.
[04:56:20.673] checksum module "subarudbw" loaded.
[04:56:20.673] flashing tool "wrx02" loaded.
[04:56:20.673] flashing tool "wrx04" loaded.
[04:56:20.673] flashing tool "sti04" loaded.
[04:56:20.673] flashing tool "sti05" loaded.
[04:56:20.673] flashing tool "mitsukernel" loaded.
[04:56:20.673] flashing tool "mitsukernelocp" loaded.
[04:56:20.673] flashing tool "mitsubootloader" loaded.
[04:56:20.673] error loading FTD2XX.DLL
[04:57:06.840] ssm2_init
[04:57:07.110] ssm2_cmd_0x81
[04:57:07.150] ssm2_cmd_0x83
[04:57:07.200] denso challenge-response
[04:57:07.250] challenge is F3 32 C3 E4
[04:57:07.250] response is 00 60 AA 13
[04:57:07.310] ssm2_cmd_0x10
[04:57:07.671] validating denso kernel ram area addr: FFFF3000 len: 0C28
[04:57:07.711] writing denso kernel area addr: FFFF3000 len: 0C28
[04:57:07.911] writing denso flash block addr: FFFF3000 len: 0080
[04:57:08.232] writing denso flash block addr: FFFF3080 len: 0080
[04:57:08.552] writing denso flash block addr: FFFF3100 len: 0080
[04:57:08.853] writing denso flash block addr: FFFF3180 len: 0080
[04:57:09.153] writing denso flash block addr: FFFF3200 len: 0080
[04:57:09.464] writing denso flash block addr: FFFF3280 len: 0080
[04:57:09.764] writing denso flash block addr: FFFF3300 len: 0080
[04:57:10.084] writing denso flash block addr: FFFF3380 len: 0080
[04:57:10.405] writing denso flash block addr: FFFF3400 len: 0080
[04:57:10.725] writing denso flash block addr: FFFF3480 len: 0080
[04:57:11.026] writing denso flash block addr: FFFF3500 len: 0080
[04:57:11.336] writing denso flash block addr: FFFF3580 len: 0080
[04:57:11.647] writing denso flash block addr: FFFF3600 len: 0080
[04:57:11.957] writing denso flash block addr: FFFF3680 len: 0080
[04:57:12.278] writing denso flash block addr: FFFF3700 len: 0080
[04:57:12.598] writing denso flash block addr: FFFF3780 len: 0080
[04:57:13.059] writing denso flash block addr: FFFF3800 len: 0080
[04:57:13.359] writing denso flash block addr: FFFF3880 len: 0080
[04:57:13.670] writing denso flash block addr: FFFF3900 len: 0080
[04:57:13.990] writing denso flash block addr: FFFF3980 len: 0080
[04:57:14.311] writing denso flash block addr: FFFF3A00 len: 0080
[04:57:14.621] writing denso flash block addr: FFFF3A80 len: 0080
[04:57:14.931] writing denso flash block addr: FFFF3B00 len: 0080
[04:57:15.252] writing denso flash block addr: FFFF3B80 len: 0080
[04:57:15.572] writing denso flash block addr: FFFF3C00 len: 0028
[04:57:17.856] entering kernel
[04:57:18.106] kernel get version
[04:57:18.126] kernel version is : OpenECU Subaru SH7058 OCP Kernel V0.21
[04:57:18.156] Dumping ECU memory...
[04:57:18.176] kernel read area: addr: 00000000 len: 0400
[04:57:18.376] kernel read area: addr: 00000400 len: 0400
[04:57:18.597] kernel read area: addr: 00000800 len: 0400
[04:57:18.797] kernel read area: addr: 00000C00 len: 0400
[04:57:18.997] kernel read area: addr: 00001000 len: 0400
[04:57:19.208] kernel read area: addr: 00001400 len: 0400
[04:57:19.428] kernel read area: addr: 00001800 len: 0400
[04:57:19.638] kernel read area: addr: 00001C00 len: 0400
[04:57:19.858] kernel read area: addr: 00002000 len: 0400
[04:57:20.079] kernel read area: addr: 00002400 len: 0400
[04:57:20.299] kernel read area: addr: 00002800 len: 0400
[04:57:20.499] kernel read area: addr: 00002C00 len: 0400
[04:57:20.720] kernel read area: addr: 00003000 len: 0400
[04:57:20.950] kernel read area: addr: 00003400 len: 0400
[04:57:21.190] kernel read area: addr: 00003800 len: 0400
[04:57:21.411] kernel read area: addr: 00003C00 len: 0400
[04:57:21.631] kernel read area: addr: 00004000 len: 0400
[04:57:21.861] kernel read area: addr: 00004400 len: 0400
[04:57:22.072] kernel read area: addr: 00004800 len: 0400
[04:57:22.272] kernel read area: addr: 00004C00 len: 0400
[04:57:22.502] kernel read area: addr: 00005000 len: 0400
[04:57:22.703] kernel read area: addr: 00005400 len: 0400
[04:57:22.923] kernel read area: addr: 00005800 len: 0400
[04:57:23.133] kernel read area: addr: 00005C00 len: 0400
[04:57:23.344] kernel read area: addr: 00006000 len: 0400
[04:57:23.554] kernel read area: addr: 00006400 len: 0400
[04:57:23.764] kernel read area: addr: 00006800 len: 0400
[04:57:23.974] kernel read area: addr: 00006C00 len: 0400
[04:57:24.185] kernel read area: addr: 00007000 len: 0400
[04:57:24.405] kernel read area: addr: 00007400 len: 0400
[04:57:24.615] kernel read area: addr: 00007800 len: 0400
[04:57:24.826] kernel read area: addr: 00007C00 len: 0400
[04:57:25.036] kernel read area: addr: 00008000 len: 0400
[04:57:25.256] kernel read area: addr: 00008400 len: 0400
[04:57:25.477] kernel read area: addr: 00008800 len: 0400
[04:57:25.687] kernel read area: addr: 00008C00 len: 0400
[04:57:25.907] kernel read area: addr: 00009000 len: 0400
[04:57:26.128] kernel read area: addr: 00009400 len: 0400
[04:57:26.348] kernel read area: addr: 00009800 len: 0400
[04:57:26.578] kernel read area: addr: 00009C00 len: 0400
[04:57:26.788] kernel read area: addr: 0000A000 len: 0400
[04:57:26.999] kernel read area: addr: 0000A400 len: 0400
[04:57:27.209] kernel read area: addr: 0000A800 len: 0400
[04:57:27.409] kernel read area: addr: 0000AC00 len: 0400
[04:57:27.620] kernel read area: addr: 0000B000 len: 0400
[04:57:27.860] kernel read area: addr: 0000B400 len: 0400
[04:57:28.080] kernel read area: addr: 0000B800 len: 0400
[04:57:28.291] kernel read area: addr: 0000BC00 len: 0400
[04:57:28.501] kernel read area: addr: 0000C000 len: 0400
[04:57:28.711] kernel read area: addr: 0000C400 len: 0400
[04:57:28.932] kernel read area: addr: 0000C800 len: 0400
[04:57:29.142] kernel read area: addr: 0000CC00 len: 0400
[04:57:29.362] kernel read area: addr: 0000D000 len: 0400
[04:57:29.582] kernel read area: addr: 0000D400 len: 0400
[04:57:29.793] kernel read area: addr: 0000D800 len: 0400
[04:57:30.003] kernel read area: addr: 0000DC00 len: 0400
[04:57:30.223] kernel read area: addr: 0000E000 len: 0400
[04:57:30.424] kernel read area: addr: 0000E400 len: 0400
[04:57:30.634] kernel read area: addr: 0000E800 len: 0400
[04:57:30.844] kernel read area: addr: 0000EC00 len: 0400
[04:57:31.055] kernel read area: addr: 0000F000 len: 0400
[04:57:31.265] kernel read area: addr: 0000F400 len: 0400
[04:57:31.485] kernel read area: addr: 0000F800 len: 0400
[04:57:31.685] kernel read area: addr: 0000FC00 len: 0400
[04:57:31.906] kernel read area: addr: 00010000 len: 0400
[04:57:32.106] kernel read area: addr: 00010400 len: 0400
[04:57:32.336] kernel read area: addr: 00010800 len: 0400
[04:57:32.557] kernel read area: addr: 00010C00 len: 0400
[04:57:32.787] kernel read area: addr: 00011000 len: 0400
[04:57:32.987] kernel read area: addr: 00011400 len: 0400
[04:57:33.198] kernel read area: addr: 00011800 len: 0400
[04:57:33.398] kernel read area: addr: 00011C00 len: 0400
[04:57:33.618] kernel read area: addr: 00012000 len: 0400
[04:57:33.839] kernel read area: addr: 00012400 len: 0400
[04:57:34.059] kernel read area: addr: 00012800 len: 0400
[04:57:34.289] kernel read area: addr: 00012C00 len: 0400
[04:57:34.500] kernel read area: addr: 00013000 len: 0400
[04:57:34.710] kernel read area: addr: 00013400 len: 0400
[04:57:34.930] kernel read area: addr: 00013800 len: 0400
[04:57:35.130] kernel read area: addr: 00013C00 len: 0400
[04:57:35.351] kernel read area: addr: 00014000 len: 0400
[04:57:35.561] kernel read area: addr: 00014400 len: 0400
[04:57:35.771] kernel read area: addr: 00014800 len: 0400
[04:57:35.972] kernel read area: addr: 00014C00 len: 0400
[04:57:36.172] kernel read area: addr: 00015000 len: 0400
[04:57:36.392] kernel read area: addr: 00015400 len: 0400
[04:57:36.603] kernel read area: addr: 00015800 len: 0400
[04:57:36.823] kernel read area: addr: 00015C00 len: 0400
[04:57:37.043] kernel read area: addr: 00016000 len: 0400
[04:57:37.254] kernel read area: addr: 00016400 len: 0400
[04:57:37.474] kernel read area: addr: 00016800 len: 0400
[04:57:37.684] kernel read area: addr: 00016C00 len: 0400
[04:57:37.904] kernel read area: addr: 00017000 len: 0400
[04:57:38.105] kernel read area: addr: 00017400 len: 0400
[04:57:38.315] kernel read area: addr: 00017800 len: 0400
[04:57:38.535] kernel read area: addr: 00017C00 len: 0400
[04:57:38.756] kernel read area: addr: 00018000 len: 0400
[04:57:38.966] kernel read area: addr: 00018400 len: 0400
[04:57:39.176] kernel read area: addr: 00018800 len: 0400
[04:57:39.397] kernel read area: addr: 00018C00 len: 0400
[04:57:39.607] kernel read area: addr: 00019000 len: 0400
[04:57:39.847] kernel read area: addr: 00019400 len: 0400
[04:57:40.068] kernel read area: addr: 00019800 len: 0400
[04:57:40.268] kernel read area: addr: 00019C00 len: 0400
[04:57:40.478] kernel read area: addr: 0001A000 len: 0400
[04:57:40.688] kernel read area: addr: 0001A400 len: 0400
[04:57:40.899] kernel read area: addr: 0001A800 len: 0400
[04:57:41.109] kernel read area: addr: 0001AC00 len: 0400
[04:57:41.329] kernel read area: addr: 0001B000 len: 0400
[04:57:41.540] kernel read area: addr: 0001B400 len: 0400
[04:57:41.750] kernel read area: addr: 0001B800 len: 0400
[04:57:41.980] kernel read area: addr: 0001BC00 len: 0400
[04:57:42.221] kernel read area: addr: 0001C000 len: 0400
[04:57:42.441] kernel read area: addr: 0001C400 len: 0400
[04:57:42.661] kernel read area: addr: 0001C800 len: 0400
[04:57:42.892] kernel read area: addr: 0001CC00 len: 0400
[04:57:43.102] kernel read area: addr: 0001D000 len: 0400
[04:57:43.302] kernel read area: addr: 0001D400 len: 0400
[04:57:43.533] kernel read area: addr: 0001D800 len: 0400
[04:57:43.743] kernel read area: addr: 0001DC00 len: 0400
[04:57:43.963] kernel read area: addr: 0001E000 len: 0400
[04:57:44.163] kernel read area: addr: 0001E400 len: 0400
[04:57:44.374] kernel read area: addr: 0001E800 len: 0400
[04:57:44.604] kernel read area: addr: 0001EC00 len: 0400
[04:57:44.814] kernel read area: addr: 0001F000 len: 0400
[04:57:45.015] kernel read area: addr: 0001F400 len: 0400
[04:57:45.225] kernel read area: addr: 0001F800 len: 0400
[04:57:45.425] kernel read area: addr: 0001FC00 len: 0400
[04:57:45.636] kernel read area: addr: 00020000 len: 0400
[04:57:45.856] kernel read area: addr: 00020400 len: 0400
[04:57:46.066] kernel read area: addr: 00020800 len: 0400
[04:57:46.297] kernel read area: addr: 00020C00 len: 0400
[04:57:46.507] kernel read area: addr: 00021000 len: 0400
[04:57:46.747] kernel read area: addr: 00021400 len: 0400
[04:57:46.967] kernel read area: addr: 00021800 len: 0400
[04:57:47.178] kernel read area: addr: 00021C00 len: 0400
[04:57:47.388] kernel read area: addr: 00022000 len: 0400
[04:57:47.608] kernel read area: addr: 00022400 len: 0400
[04:57:47.819] kernel read area: addr: 00022800 len: 0400
[04:57:48.019] kernel read area: addr: 00022C00 len: 0400
[04:57:48.229] kernel read area: addr: 00023000 len: 0400
[04:57:48.430] kernel read area: addr: 00023400 len: 0400
[04:57:48.640] kernel read area: addr: 00023800 len: 0400
[04:57:48.850] kernel read area: addr: 00023C00 len: 0400
[04:57:49.091] kernel read area: addr: 00024000 len: 0400
[04:57:49.311] kernel read area: addr: 00024400 len: 0400
[04:57:49.521] kernel read area: addr: 00024800 len: 0400
[04:57:49.731] kernel read area: addr: 00024C00 len: 0400
[04:57:49.952] kernel read area: addr: 00025000 len: 0400
[04:57:50.152] kernel read area: addr: 00025400 len: 0400
[04:57:50.362] kernel read area: addr: 00025800 len: 0400
[04:57:50.593] kernel read area: addr: 00025C00 len: 0400
[04:57:50.803] kernel read area: addr: 00026000 len: 0400
[04:57:51.023] kernel read area: addr: 00026400 len: 0400
[04:57:51.234] kernel read area: addr: 00026800 len: 0400
[04:57:51.444] kernel read area: addr: 00026C00 len: 0400
[04:57:51.664] kernel read area: addr: 00027000 len: 0400
[04:57:51.865] kernel read area: addr: 00027400 len: 0400
[04:57:52.085] kernel read area: addr: 00027800 len: 0400
[04:57:52.295] kernel read area: addr: 00027C00 len: 0400
[04:57:52.515] kernel read area: addr: 00028000 len: 0400
[04:57:52.726] kernel read area: addr: 00028400 len: 0400
[04:57:52.936] kernel read area: addr: 00028800 len: 0400
[04:57:53.146] kernel read area: addr: 00028C00 len: 0400
[04:57:53.367] kernel read area: addr: 00029000 len: 0400
[04:57:53.577] kernel read area: addr: 00029400 len: 0400
[04:57:53.787] kernel read area: addr: 00029800 len: 0400
[04:57:53.998] kernel read area: addr: 00029C00 len: 0400
[04:57:54.218] kernel read area: addr: 0002A000 len: 0400
[04:57:54.418] kernel read area: addr: 0002A400 len: 0400
[04:57:54.639] kernel read area: addr: 0002A800 len: 0400
[04:57:54.869] kernel read area: addr: 0002AC00 len: 0400
[04:57:55.089] kernel read area: addr: 0002B000 len: 0400
[04:57:55.299] kernel read area: addr: 0002B400 len: 0400
[04:57:55.510] kernel read area: addr: 0002B800 len: 0400
[04:57:55.720] kernel read area: addr: 0002BC00 len: 0400
[04:57:55.940] kernel read area: addr: 0002C000 len: 0400
[04:57:56.161] kernel read area: addr: 0002C400 len: 0400
[04:57:56.381] kernel read area: addr: 0002C800 len: 0400
[04:57:56.591] kernel read area: addr: 0002CC00 len: 0400
[04:57:56.812] kernel read area: addr: 0002D000 len: 0400
[04:57:57.022] kernel read area: addr: 0002D400 len: 0400
[04:57:57.232] kernel read area: addr: 0002D800 len: 0400
[04:57:57.463] kernel read area: addr: 0002DC00 len: 0400
[04:57:57.673] kernel read area: addr: 0002E000 len: 0400
[04:57:57.883] kernel read area: addr: 0002E400 len: 0400
[04:57:58.103] kernel read area: addr: 0002E800 len: 0400
[04:57:58.334] kernel read area: addr: 0002EC00 len: 0400
[04:57:58.554] kernel read area: addr: 0002F000 len: 0400
[04:57:58.764] kernel read area: addr: 0002F400 len: 0400
[04:57:58.985] kernel read area: addr: 0002F800 len: 0400
[04:57:59.185] kernel read area: addr: 0002FC00 len: 0400
[04:57:59.395] kernel read area: addr: 00030000 len: 0400
[04:57:59.606] kernel read area: addr: 00030400 len: 0400
[04:57:59.816] kernel read area: addr: 00030800 len: 0400
[04:58:00.026] kernel read area: addr: 00030C00 len: 0400
[04:58:00.247] kernel read area: addr: 00031000 len: 0400
[04:58:00.447] kernel read area: addr: 00031400 len: 0400
[04:58:00.667] kernel read area: addr: 00031800 len: 0400
[04:58:00.898] kernel read area: addr: 00031C00 len: 0400
[04:58:01.108] kernel read area: addr: 00032000 len: 0400
[04:58:01.318] kernel read area: addr: 00032400 len: 0400
[04:58:01.528] kernel read area: addr: 00032800 len: 0400
[04:58:01.739] kernel read area: addr: 00032C00 len: 0400
[04:58:01.959] kernel read area: addr: 00033000 len: 0400
[04:58:02.159] kernel read area: addr: 00033400 len: 0400
[04:58:02.370] kernel read area: addr: 00033800 len: 0400
[04:58:02.570] kernel read area: addr: 00033C00 len: 0400
[04:58:02.790] kernel read area: addr: 00034000 len: 0400
[04:58:03.021] kernel read area: addr: 00034400 len: 0400
[04:58:03.231] kernel read area: addr: 00034800 len: 0400
[04:58:03.441] kernel read area: addr: 00034C00 len: 0400
[04:58:03.661] kernel read area: addr: 00035000 len: 0400
[04:58:03.892] kernel read area: addr: 00035400 len: 0400
[04:58:04.102] kernel read area: addr: 00035800 len: 0400
[04:58:04.312] kernel read area: addr: 00035C00 len: 0400
[04:58:04.533] kernel read area: addr: 00036000 len: 0400
[04:58:04.743] kernel read area: addr: 00036400 len: 0400
[04:58:04.963] kernel read area: addr: 00036800 len: 0400
[04:58:05.174] kernel read area: addr: 00036C00 len: 0400
[04:58:05.404] kernel read area: addr: 00037000 len: 0400
[04:58:05.614] kernel read area: addr: 00037400 len: 0400
[04:58:05.825] kernel read area: addr: 00037800 len: 0400
[04:58:06.035] kernel read area: addr: 00037C00 len: 0400
[04:58:06.245] kernel read area: addr: 00038000 len: 0400
[04:58:06.445] kernel read area: addr: 00038400 len: 0400
[04:58:06.656] kernel read area: addr: 00038800 len: 0400
[04:58:06.876] kernel read area: addr: 00038C00 len: 0400
[04:58:07.096] kernel read area: addr: 00039000 len: 0400
[04:58:07.327] kernel read area: addr: 00039400 len: 0400
[04:58:07.547] kernel read area: addr: 00039800 len: 0400
[04:58:07.757] kernel read area: addr: 00039C00 len: 0400
[04:58:07.968] kernel read area: addr: 0003A000 len: 0400
[04:58:08.178] kernel read area: addr: 0003A400 len: 0400
[04:58:08.398] kernel read area: addr: 0003A800 len: 0400
[04:58:08.609] kernel read area: addr: 0003AC00 len: 0400
[04:58:08.829] kernel read area: addr: 0003B000 len: 0400
[04:58:09.059] kernel read area: addr: 0003B400 len: 0400
[04:58:09.270] kernel read area: addr: 0003B800 len: 0400
[04:58:09.480] kernel read area: addr: 0003BC00 len: 0400
[04:58:09.700] kernel read area: addr: 0003C000 len: 0400
[04:58:09.920] kernel read area: addr: 0003C400 len: 0400
[04:58:10.131] kernel read area: addr: 0003C800 len: 0400
[04:58:10.341] kernel read area: addr: 0003CC00 len: 0400
[04:58:10.551] kernel read area: addr: 0003D000 len: 0400
[04:58:10.762] kernel read area: addr: 0003D400 len: 0400
[04:58:10.982] kernel read area: addr: 0003D800 len: 0400
[04:58:11.182] kernel read area: addr: 0003DC00 len: 0400
[04:58:11.403] kernel read area: addr: 0003E000 len: 0400
[04:58:11.613] kernel read area: addr: 0003E400 len: 0400
[04:58:11.823] kernel read area: addr: 0003E800 len: 0400
[04:58:12.054] kernel read area: addr: 0003EC00 len: 0400
[04:58:12.264] kernel read area: addr: 0003F000 len: 0400
[04:58:12.464] kernel read area: addr: 0003F400 len: 0400
[04:58:12.674] kernel read area: addr: 0003F800 len: 0400
[04:58:12.905] kernel read area: addr: 0003FC00 len: 0400
[04:58:13.125] kernel read area: addr: 00040000 len: 0400
[04:58:13.335] kernel read area: addr: 00040400 len: 0400
[04:58:13.546] kernel read area: addr: 00040800 len: 0400
[04:58:13.756] kernel read area: addr: 00040C00 len: 0400
[04:58:13.976] kernel read area: addr: 00041000 len: 0400
[04:58:14.177] kernel read area: addr: 00041400 len: 0400
[04:58:14.407] kernel read area: addr: 00041800 len: 0400
[04:58:14.617] kernel read area: addr: 00041C00 len: 0400
[04:58:14.828] kernel read area: addr: 00042000 len: 0400
[04:58:15.038] kernel read area: addr: 00042400 len: 0400
[04:58:15.268] kernel read area: addr: 00042800 len: 0400
[04:58:15.478] kernel read area: addr: 00042C00 len: 0400
[04:58:15.689] kernel read area: addr: 00043000 len: 0400
[04:58:15.899] kernel read area: addr: 00043400 len: 0400
[04:58:16.109] kernel read area: addr: 00043800 len: 0400
[04:58:16.350] kernel read area: addr: 00043C00 len: 0400
[04:58:16.570] kernel read area: addr: 00044000 len: 0400
[04:58:16.780] kernel read area: addr: 00044400 len: 0400
[04:58:17.001] kernel read area: addr: 00044800 len: 0400
[04:58:17.211] kernel read area: addr: 00044C00 len: 0400
[04:58:17.421] kernel read area: addr: 00045000 len: 0400
[04:58:17.632] kernel read area: addr: 00045400 len: 0400
[04:58:17.842] kernel read area: addr: 00045800 len: 0400
[04:58:18.052] kernel read area: addr: 00045C00 len: 0400
[04:58:18.272] kernel read area: addr: 00046000 len: 0400
[04:58:18.473] kernel read area: addr: 00046400 len: 0400
[04:58:18.693] kernel read area: addr: 00046800 len: 0400
[04:58:18.923] kernel read area: addr: 00046C00 len: 0400
[04:58:19.134] kernel read area: addr: 00047000 len: 0400
[04:58:19.344] kernel read area: addr: 00047400 len: 0400
[04:58:19.554] kernel read area: addr: 00047800 len: 0400
[04:58:19.775] kernel read area: addr: 00047C00 len: 0400
[04:58:19.985] kernel read area: addr: 00048000 len: 0400
[04:58:20.195] kernel read area: addr: 00048400 len: 0400
[04:58:20.416] kernel read area: addr: 00048800 len: 0400
[04:58:20.616] kernel read area: addr: 00048C00 len: 0400
[04:58:20.826] kernel read area: addr: 00049000 len: 0400
[04:58:21.046] kernel read area: addr: 00049400 len: 0400
[04:58:21.257] kernel read area: addr: 00049800 len: 0400
[04:58:21.467] kernel read area: addr: 00049C00 len: 0400
[04:58:21.677] kernel read area: addr: 0004A000 len: 0400
[04:58:21.898] kernel read area: addr: 0004A400 len: 0400
[04:58:22.118] kernel read area: addr: 0004A800 len: 0400
[04:58:22.318] kernel read area: addr: 0004AC00 len: 0400
[04:58:22.539] kernel read area: addr: 0004B000 len: 0400
[04:58:22.749] kernel read area: addr: 0004B400 len: 0400
[04:58:22.969] kernel read area: addr: 0004B800 len: 0400
[04:58:23.190] kernel read area: addr: 0004BC00 len: 0400
[04:58:23.400] kernel read area: addr: 0004C000 len: 0400
[04:58:23.610] kernel read area: addr: 0004C400 len: 0400
[04:58:23.820] kernel read area: addr: 0004C800 len: 0400
[04:58:24.031] kernel read area: addr: 0004CC00 len: 0400
[04:58:24.251] kernel read area: addr: 0004D000 len: 0400
[04:58:24.451] kernel read area: addr: 0004D400 len: 0400
[04:58:24.672] kernel read area: addr: 0004D800 len: 0400
[04:58:24.882] kernel read area: addr: 0004DC00 len: 0400
[04:58:25.112] kernel read area: addr: 0004E000 len: 0400
[04:58:25.333] kernel read area: addr: 0004E400 len: 0400
[04:58:25.553] kernel read area: addr: 0004E800 len: 0400
[04:58:25.763] kernel read area: addr: 0004EC00 len: 0400
[04:58:25.984] kernel read area: addr: 0004F000 len: 0400
[04:58:26.184] kernel read area: addr: 0004F400 len: 0400
[04:58:26.414] kernel read area: addr: 0004F800 len: 0400
[04:58:26.624] kernel read area: addr: 0004FC00 len: 0400
[04:58:26.835] kernel read area: addr: 00050000 len: 0400
[04:58:27.025] kernel read area: addr: 00050400 len: 0400
[04:58:27.235] kernel read area: addr: 00050800 len: 0400
[04:58:27.466] kernel read area: addr: 00050C00 len: 0400
[04:58:27.676] kernel read area: addr: 00051000 len: 0400
[04:58:27.886] kernel read area: addr: 00051400 len: 0400
[04:58:28.097] kernel read area: addr: 00051800 len: 0400
[04:58:28.307] kernel read area: addr: 00051C00 len: 0400
[04:58:28.517] kernel read area: addr: 00052000 len: 0400
[04:58:28.728] kernel read area: addr: 00052400 len: 0400
[04:58:28.948] kernel read area: addr: 00052800 len: 0400
[04:58:29.168] kernel read area: addr: 00052C00 len: 0400
[04:58:29.378] kernel read area: addr: 00053000 len: 0400
[04:58:29.589] kernel read area: addr: 00053400 len: 0400
[04:58:29.799] kernel read area: addr: 00053800 len: 0400
[04:58:30.009] kernel read area: addr: 00053C00 len: 0400
[04:58:30.230] kernel read area: addr: 00054000 len: 0400
[04:58:30.430] kernel read area: addr: 00054400 len: 0400
[04:58:30.650] kernel read area: addr: 00054800 len: 0400
[04:58:30.851] kernel read area: addr: 00054C00 len: 0400
[04:58:31.061] kernel read area: addr: 00055000 len: 0400
[04:58:31.261] kernel read area: addr: 00055400 len: 0400
[04:58:31.481] kernel read area: addr: 00055800 len: 0400
[04:58:31.692] kernel read area: addr: 00055C00 len: 0400
[04:58:31.912] kernel read area: addr: 00056000 len: 0400
[04:58:32.122] kernel read area: addr: 00056400 len: 0400
[04:58:32.333] kernel read area: addr: 00056800 len: 0400
[04:58:32.543] kernel read area: addr: 00056C00 len: 0400
[04:58:32.753] kernel read area: addr: 00057000 len: 0400
[04:58:32.974] kernel read area: addr: 00057400 len: 0400
[04:58:33.194] kernel read area: addr: 00057800 len: 0400
[04:58:33.404] kernel read area: addr: 00057C00 len: 0400
[04:58:33.615] kernel read area: addr: 00058000 len: 0400
[04:58:33.815] kernel read area: addr: 00058400 len: 0400
[04:58:34.035] kernel read area: addr: 00058800 len: 0400
[04:58:34.235] kernel read area: addr: 00058C00 len: 0400
[04:58:34.466] kernel read area: addr: 00059000 len: 0400
[04:58:34.676] kernel read area: addr: 00059400 len: 0400
[04:58:34.886] kernel read area: addr: 00059800 len: 0400
[04:58:35.097] kernel read area: addr: 00059C00 len: 0400
[04:58:35.317] kernel read area: addr: 0005A000 len: 0400
[04:58:35.527] kernel read area: addr: 0005A400 len: 0400
[04:58:35.738] kernel read area: addr: 0005A800 len: 0400
[04:58:35.948] kernel read area: addr: 0005AC00 len: 0400
[04:58:36.168] kernel read area: addr: 0005B000 len: 0400
[04:58:36.379] kernel read area: addr: 0005B400 len: 0400
[04:58:36.599] kernel read area: addr: 0005B800 len: 0400
[04:58:36.809] kernel read area: addr: 0005BC00 len: 0400
[04:58:37.019] kernel read area: addr: 0005C000 len: 0400
[04:58:37.250] kernel read area: addr: 0005C400 len: 0400
[04:58:37.470] kernel read area: addr: 0005C800 len: 0400
[04:58:37.680] kernel read area: addr: 0005CC00 len: 0400
[04:58:37.901] kernel read area: addr: 0005D000 len: 0400
[04:58:38.101] kernel read area: addr: 0005D400 len: 0400
[04:58:38.311] kernel read area: addr: 0005D800 len: 0400
[04:58:38.532] kernel read area: addr: 0005DC00 len: 0400
[04:58:38.752] kernel read area: addr: 0005E000 len: 0400
[04:58:38.952] kernel read area: addr: 0005E400 len: 0400
[04:58:39.173] kernel read area: addr: 0005E800 len: 0400
[04:58:39.383] kernel read area: addr: 0005EC00 len: 0400
[04:58:39.593] kernel read area: addr: 0005F000 len: 0400
[04:58:39.803] kernel read area: addr: 0005F400 len: 0400
[04:58:40.024] kernel read area: addr: 0005F800 len: 0400
[04:58:40.224] kernel read area: addr: 0005FC00 len: 0400
[04:58:40.424] kernel read area: addr: 00060000 len: 0400
[04:58:40.635] kernel read area: addr: 00060400 len: 0400
[04:58:40.845] kernel read area: addr: 00060800 len: 0400
[04:58:41.065] kernel read area: addr: 00060C00 len: 0400
[04:58:41.286] kernel read area: addr: 00061000 len: 0400
[04:58:41.496] kernel read area: addr: 00061400 len: 0400
[04:58:41.696] kernel read area: addr: 00061800 len: 0400
[04:58:41.906] kernel read area: addr: 00061C00 len: 0400
[04:58:42.127] kernel read area: addr: 00062000 len: 0400
[04:58:42.327] kernel read area: addr: 00062400 len: 0400
[04:58:42.537] kernel read area: addr: 00062800 len: 0400
[04:58:42.748] kernel read area: addr: 00062C00 len: 0400
[04:58:42.968] kernel read area: addr: 00063000 len: 0400
[04:58:43.198] kernel read area: addr: 00063400 len: 0400
[04:58:43.409] kernel read area: addr: 00063800 len: 0400
[04:58:43.619] kernel read area: addr: 00063C00 len: 0400
[04:58:43.849] kernel read area: addr: 00064000 len: 0400
[04:58:44.060] kernel read area: addr: 00064400 len: 0400
[04:58:44.280] kernel read area: addr: 00064800 len: 0400
[04:58:44.480] kernel read area: addr: 00064C00 len: 0400
[04:58:44.700] kernel read area: addr: 00065000 len: 0400
[04:58:44.901] kernel read area: addr: 00065400 len: 0400
[04:58:45.121] kernel read area: addr: 00065800 len: 0400
[04:58:45.331] kernel read area: addr: 00065C00 len: 0400
[04:58:45.532] kernel read area: addr: 00066000 len: 0400
[04:58:45.742] kernel read area: addr: 00066400 len: 0400
[04:58:45.952] kernel read area: addr: 00066800 len: 0400
[04:58:46.163] kernel read area: addr: 00066C00 len: 0400
[04:58:46.373] kernel read area: addr: 00067000 len: 0400
[04:58:46.583] kernel read area: addr: 00067400 len: 0400
[04:58:46.804] kernel read area: addr: 00067800 len: 0400
[04:58:47.014] kernel read area: addr: 00067C00 len: 0400
[04:58:47.254] kernel read area: addr: 00068000 len: 0400
[04:58:47.464] kernel read area: addr: 00068400 len: 0400
[04:58:47.675] kernel read area: addr: 00068800 len: 0400
[04:58:47.885] kernel read area: addr: 00068C00 len: 0400
[04:58:48.095] kernel read area: addr: 00069000 len: 0400
[04:58:48.306] kernel read area: addr: 00069400 len: 0400
[04:58:48.526] kernel read area: addr: 00069800 len: 0400
[04:58:48.736] kernel read area: addr: 00069C00 len: 0400
[04:58:48.957] kernel read area: addr: 0006A000 len: 0400
[04:58:49.167] kernel read area: addr: 0006A400 len: 0400
[04:58:49.377] kernel read area: addr: 0006A800 len: 0400
[04:58:49.598] kernel read area: addr: 0006AC00 len: 0400
[04:58:49.818] kernel read area: addr: 0006B000 len: 0400
[04:58:50.028] kernel read area: addr: 0006B400 len: 0400
[04:58:50.248] kernel read area: addr: 0006B800 len: 0400
[04:58:50.449] kernel read area: addr: 0006BC00 len: 0400
[04:58:50.669] kernel read area: addr: 0006C000 len: 0400
[04:58:50.879] kernel read area: addr: 0006C400 len: 0400
[04:58:51.090] kernel read area: addr: 0006C800 len: 0400
[04:58:51.300] kernel read area: addr: 0006CC00 len: 0400
[04:58:51.520] kernel read area: addr: 0006D000 len: 0400
[04:58:51.731] kernel read area: addr: 0006D400 len: 0400
[04:58:51.951] kernel read area: addr: 0006D800 len: 0400
[04:58:52.161] kernel read area: addr: 0006DC00 len: 0400
[04:58:52.402] kernel read area: addr: 0006E000 len: 0400
[04:58:52.622] kernel read area: addr: 0006E400 len: 0400
[04:58:52.832] kernel read area: addr: 0006E800 len: 0400
[04:58:53.052] kernel read area: addr: 0006EC00 len: 0400
[04:58:53.263] kernel read area: addr: 0006F000 len: 0400
[04:58:53.473] kernel read area: addr: 0006F400 len: 0400
[04:58:53.693] kernel read area: addr: 0006F800 len: 0400
[04:58:53.904] kernel read area: addr: 0006FC00 len: 0400
[04:58:54.114] kernel read area: addr: 00070000 len: 0400
[04:58:54.324] kernel read area: addr: 00070400 len: 0400
[04:58:54.535] kernel read area: addr: 00070800 len: 0400
[04:58:54.745] kernel read area: addr: 00070C00 len: 0400
[04:58:54.965] kernel read area: addr: 00071000 len: 0400
[04:58:55.186] kernel read area: addr: 00071400 len: 0400
[04:58:55.406] kernel read area: addr: 00071800 len: 0400
[04:58:55.616] kernel read area: addr: 00071C00 len: 0400
[04:58:55.826] kernel read area: addr: 00072000 len: 0400
[04:58:56.047] kernel read area: addr: 00072400 len: 0400
[04:58:56.267] kernel read area: addr: 00072800 len: 0400
[04:58:56.477] kernel read area: addr: 00072C00 len: 0400
[04:58:56.688] kernel read area: addr: 00073000 len: 0400
[04:58:56.898] kernel read area: addr: 00073400 len: 0400
[04:58:57.098] kernel read area: addr: 00073800 len: 0400
[04:58:57.319] kernel read area: addr: 00073C00 len: 0400
[04:58:57.539] kernel read area: addr: 00074000 len: 0400
[04:58:57.749] kernel read area: addr: 00074400 len: 0400
[04:58:57.970] kernel read area: addr: 00074800 len: 0400
[04:58:58.170] kernel read area: addr: 00074C00 len: 0400
[04:58:58.380] kernel read area: addr: 00075000 len: 0400
[04:58:58.590] kernel read area: addr: 00075400 len: 0400
[04:58:58.801] kernel read area: addr: 00075800 len: 0400
[04:58:59.011] kernel read area: addr: 00075C00 len: 0400
[04:58:59.231] kernel read area: addr: 00076000 len: 0400
[04:58:59.442] kernel read area: addr: 00076400 len: 0400
[04:58:59.672] kernel read area: addr: 00076800 len: 0400
[04:58:59.892] kernel read area: addr: 00076C00 len: 0400
[04:59:00.103] kernel read area: addr: 00077000 len: 0400
[04:59:00.313] kernel read area: addr: 00077400 len: 0400
[04:59:00.533] kernel read area: addr: 00077800 len: 0400
[04:59:00.744] kernel read area: addr: 00077C00 len: 0400
[04:59:00.964] kernel read area: addr: 00078000 len: 0400
[04:59:01.174] kernel read area: addr: 00078400 len: 0400
[04:59:01.405] kernel read area: addr: 00078800 len: 0400
[04:59:01.615] kernel read area: addr: 00078C00 len: 0400
[04:59:01.835] kernel read area: addr: 00079000 len: 0400
[04:59:02.045] kernel read area: addr: 00079400 len: 0400
[04:59:02.256] kernel read area: addr: 00079800 len: 0400
[04:59:02.466] kernel read area: addr: 00079C00 len: 0400
[04:59:02.676] kernel read area: addr: 0007A000 len: 0400
[04:59:02.887] kernel read area: addr: 0007A400 len: 0400
[04:59:03.107] kernel read area: addr: 0007A800 len: 0400
[04:59:03.317] kernel read area: addr: 0007AC00 len: 0400
[04:59:03.528] kernel read area: addr: 0007B000 len: 0400
[04:59:03.748] kernel read area: addr: 0007B400 len: 0400
[04:59:03.958] kernel read area: addr: 0007B800 len: 0400
[04:59:04.168] kernel read area: addr: 0007BC00 len: 0400
[04:59:04.379] kernel read area: addr: 0007C000 len: 0400
[04:59:04.609] kernel read area: addr: 0007C400 len: 0400
[04:59:04.829] kernel read area: addr: 0007C800 len: 0400
[04:59:05.040] kernel read area: addr: 0007CC00 len: 0400
[04:59:05.250] kernel read area: addr: 0007D000 len: 0400
[04:59:05.470] kernel read area: addr: 0007D400 len: 0400
[04:59:05.681] kernel read area: addr: 0007D800 len: 0400
[04:59:05.911] kernel read area: addr: 0007DC00 len: 0400
[04:59:06.131] kernel read area: addr: 0007E000 len: 0400
[04:59:06.342] kernel read area: addr: 0007E400 len: 0400
[04:59:06.562] kernel read area: addr: 0007E800 len: 0400
[04:59:06.762] kernel read area: addr: 0007EC00 len: 0400
[04:59:06.993] kernel read area: addr: 0007F000 len: 0400
[04:59:07.213] kernel read area: addr: 0007F400 len: 0400
[04:59:07.423] kernel read area: addr: 0007F800 len: 0400
[04:59:07.653] kernel read area: addr: 0007FC00 len: 0400
[04:59:07.874] kernel read area: addr: 00080000 len: 0400
[04:59:08.084] kernel read area: addr: 00080400 len: 0400
[04:59:08.304] kernel read area: addr: 00080800 len: 0400
[04:59:08.505] kernel read area: addr: 00080C00 len: 0400
[04:59:08.725] kernel read area: addr: 00081000 len: 0400
[04:59:08.935] kernel read area: addr: 00081400 len: 0400
[04:59:09.146] kernel read area: addr: 00081800 len: 0400
[04:59:09.356] kernel read area: addr: 00081C00 len: 0400
[04:59:09.566] kernel read area: addr: 00082000 len: 0400
[04:59:09.777] kernel read area: addr: 00082400 len: 0400
[04:59:09.997] kernel read area: addr: 00082800 len: 0400
[04:59:10.217] kernel read area: addr: 00082C00 len: 0400
[04:59:10.427] kernel read area: addr: 00083000 len: 0400
[04:59:10.638] kernel read area: addr: 00083400 len: 0400
[04:59:10.848] kernel read area: addr: 00083800 len: 0400
[04:59:11.058] kernel read area: addr: 00083C00 len: 0400
[04:59:11.279] kernel read area: addr: 00084000 len: 0400
[04:59:11.489] kernel read area: addr: 00084400 len: 0400
[04:59:11.709] kernel read area: addr: 00084800 len: 0400
[04:59:11.920] kernel read area: addr: 00084C00 len: 0400
[04:59:12.130] kernel read area: addr: 00085000 len: 0400
[04:59:12.340] kernel read area: addr: 00085400 len: 0400
[04:59:12.561] kernel read area: addr: 00085800 len: 0400
[04:59:12.771] kernel read area: addr: 00085C00 len: 0400
[04:59:12.991] kernel read area: addr: 00086000 len: 0400
[04:59:13.211] kernel read area: addr: 00086400 len: 0400
[04:59:13.422] kernel read area: addr: 00086800 len: 0400
[04:59:13.622] kernel read area: addr: 00086C00 len: 0400
[04:59:13.842] kernel read area: addr: 00087000 len: 0400
[04:59:14.053] kernel read area: addr: 00087400 len: 0400
[04:59:14.263] kernel read area: addr: 00087800 len: 0400
[04:59:14.483] kernel read area: addr: 00087C00 len: 0400
[04:59:14.694] kernel read area: addr: 00088000 len: 0400
[04:59:14.904] kernel read area: addr: 00088400 len: 0400
[04:59:15.114] kernel read area: addr: 00088800 len: 0400
[04:59:15.325] kernel read area: addr: 00088C00 len: 0400
[04:59:15.535] kernel read area: addr: 00089000 len: 0400
[04:59:15.745] kernel read area: addr: 00089400 len: 0400
[04:59:15.965] kernel read area: addr: 00089800 len: 0400
[04:59:16.186] kernel read area: addr: 00089C00 len: 0400
[04:59:16.396] kernel read area: addr: 0008A000 len: 0400
[04:59:16.606] kernel read area: addr: 0008A400 len: 0400
[04:59:16.827] kernel read area: addr: 0008A800 len: 0400
[04:59:17.027] kernel read area: addr: 0008AC00 len: 0400
[04:59:17.247] kernel read area: addr: 0008B000 len: 0400
[04:59:17.478] kernel read area: addr: 0008B400 len: 0400
[04:59:17.688] kernel read area: addr: 0008B800 len: 0400
[04:59:17.898] kernel read area: addr: 0008BC00 len: 0400
[04:59:18.109] kernel read area: addr: 0008C000 len: 0400
[04:59:18.329] kernel read area: addr: 0008C400 len: 0400
[04:59:18.549] kernel read area: addr: 0008C800 len: 0400
[04:59:18.759] kernel read area: addr: 0008CC00 len: 0400
[04:59:18.980] kernel read area: addr: 0008D000 len: 0400
[04:59:19.190] kernel read area: addr: 0008D400 len: 0400
[04:59:19.420] kernel read area: addr: 0008D800 len: 0400
[04:59:19.631] kernel read area: addr: 0008DC00 len: 0400
[04:59:19.851] kernel read area: addr: 0008E000 len: 0400
[04:59:20.051] kernel read area: addr: 0008E400 len: 0400
[04:59:20.272] kernel read area: addr: 0008E800 len: 0400
[04:59:20.492] kernel read area: addr: 0008EC00 len: 0400
[04:59:20.702] kernel read area: addr: 0008F000 len: 0400
[04:59:20.913] kernel read area: addr: 0008F400 len: 0400
[04:59:21.133] kernel read area: addr: 0008F800 len: 0400
[04:59:21.343] kernel read area: addr: 0008FC00 len: 0400
[04:59:21.553] kernel read area: addr: 00090000 len: 0400
[04:59:21.774] kernel read area: addr: 00090400 len: 0400
[04:59:21.994] kernel read area: addr: 00090800 len: 0400
[04:59:22.204] kernel read area: addr: 00090C00 len: 0400
[04:59:22.415] kernel read area: addr: 00091000 len: 0400
[04:59:22.645] kernel read area: addr: 00091400 len: 0400
[04:59:22.855] kernel read area: addr: 00091800 len: 0400
[04:59:23.066] kernel read area: addr: 00091C00 len: 0400
[04:59:23.286] kernel read area: addr: 00092000 len: 0400
[04:59:23.496] kernel read area: addr: 00092400 len: 0400
[04:59:23.707] kernel read area: addr: 00092800 len: 0400
[04:59:23.937] kernel read area: addr: 00092C00 len: 0400
[04:59:24.157] kernel read area: addr: 00093000 len: 0400
[04:59:24.368] kernel read area: addr: 00093400 len: 0400
[04:59:24.588] kernel read area: addr: 00093800 len: 0400
[04:59:24.788] kernel read area: addr: 00093C00 len: 0400
[04:59:24.998] kernel read area: addr: 00094000 len: 0400
[04:59:25.209] kernel read area: addr: 00094400 len: 0400
[04:59:25.419] kernel read area: addr: 00094800 len: 0400
[04:59:25.649] kernel read area: addr: 00094C00 len: 0400
[04:59:25.860] kernel read area: addr: 00095000 len: 0400
[04:59:26.060] kernel read area: addr: 00095400 len: 0400
[04:59:26.260] kernel read area: addr: 00095800 len: 0400
[04:59:26.471] kernel read area: addr: 00095C00 len: 0400
[04:59:26.671] kernel read area: addr: 00096000 len: 0400
[04:59:26.881] kernel read area: addr: 00096400 len: 0400
[04:59:30.466] kernel read area: addr: 000BC800 len: 0400
[04:59:30.697] kernel read area: addr: 000BCC00 len: 0400
[04:59:30.917] kernel read area: addr: 000BD000 len: 0400
[04:59:31.127] kernel read area: addr: 000BD400 len: 0400
[04:59:31.348] kernel read area: addr: 000BD800 len: 0400
[04:59:31.548] kernel read area: addr: 000BDC00 len: 0400
[04:59:31.768] kernel read area: addr: 000BE000 len: 0400
[04:59:31.978] kernel read area: addr: 000BE400 len: 0400
[04:59:32.189] kernel read area: addr: 000BE800 len: 0400
[04:59:32.419] kernel read area: addr: 000BF000 len: 0400
[04:59:32.720] kernel read area: addr: 000C0000 len: 0400
[04:59:32.930] kernel read area: addr: 000C0400 len: 0400
[04:59:33.160] kernel read area: addr: 000C0800 len: 0400
[04:59:33.380] kernel read area: addr: 000C0C00 len: 0400
[04:59:33.591] kernel read area: addr: 000C1000 len: 0400
[04:59:33.801] kernel read area: addr: 000C1400 len: 0400
[04:59:34.021] kernel read area: addr: 000C1800 len: 0400
[04:59:34.222] kernel read area: addr: 000C1C00 len: 0400
[04:59:34.442] kernel read area: addr: 000C2000 len: 0400
[04:59:34.652] kernel read area: addr: 000C2400 len: 0400
[04:59:34.863] kernel read area: addr: 000C2800 len: 0400
[04:59:35.093] kernel read area: addr: 000C2C00 len: 0400
[04:59:35.303] kernel read area: addr: 000C3000 len: 0400
[04:59:35.514] kernel read area: addr: 000C3400 len: 0400
[04:59:35.724] kernel read area: addr: 000C3800 len: 0400
[04:59:35.934] kernel read area: addr: 000C3C00 len: 0400
[04:59:36.154] kernel read area: addr: 000C4000 len: 0400
[04:59:36.365] kernel read area: addr: 000C4400 len: 0400
[04:59:36.595] kernel read area: addr: 000C4800 len: 0400
[04:59:36.805] kernel read area: addr: 000C4C00 len: 0400
[04:59:37.026] kernel read area: addr: 000C5000 len: 0400
[04:59:37.246] kernel read area: addr: 000C5400 len: 0400
[04:59:37.446] kernel read area: addr: 000C5800 len: 0400
[04:59:37.667] kernel read area: addr: 000C5C00 len: 0400
[04:59:37.887] kernel read area: addr: 000C6000 len: 0400
[04:59:38.097] kernel read area: addr: 000C6400 len: 0400
[04:59:38.318] kernel read area: addr: 000C6800 len: 0400
[04:59:38.528] kernel read area: addr: 000C6C00 len: 0400
[04:59:38.748] kernel read area: addr: 000C7000 len: 0400
[04:59:38.959] kernel read area: addr: 000C7400 len: 0400
[04:59:39.179] kernel read area: addr: 000C7800 len: 0400
[04:59:39.389] kernel read area: addr: 000C7C00 len: 0400
[04:59:39.609] kernel read area: addr: 000C8000 len: 0400
[04:59:39.820] kernel read area: addr: 000C8400 len: 0400
[04:59:40.050] kernel read area: addr: 000C8800 len: 0400
[04:59:40.260] kernel read area: addr: 000C8C00 len: 0400
[04:59:40.471] kernel read area: addr: 000C9000 len: 0400
[04:59:40.701] kernel read area: addr: 000C9400 len: 0400
[04:59:40.911] kernel read area: addr: 000C9800 len: 0400
[04:59:41.122] kernel read area: addr: 000C9C00 len: 0400
[04:59:41.332] kernel read area: addr: 000CA000 len: 0400
[04:59:41.552] kernel read area: addr: 000CA400 len: 0400
[04:59:41.763] kernel read area: addr: 000CA800 len: 0400
[04:59:41.993] kernel read area: addr: 000CAC00 len: 0400
[04:59:42.213] kernel read area: addr: 000CB000 len: 0400
[04:59:42.423] kernel read area: addr: 000CB400 len: 0400
[04:59:42.644] kernel read area: addr: 000CB800 len: 0400
[04:59:42.854] kernel read area: addr: 000CBC00 len: 0400
[04:59:43.074] kernel read area: addr: 000CC000 len: 0400
[04:59:43.275] kernel read area: addr: 000CC400 len: 0400
[04:59:43.495] kernel read area: addr: 000CC800 len: 0400
[04:59:43.705] kernel read area: addr: 000CCC00 len: 0400
[04:59:43.926] kernel read area: addr: 000CD000 len: 0400
[04:59:44.136] kernel read area: addr: 000CD400 len: 0400
[04:59:44.346] kernel read area: addr: 000CD800 len: 0400
[04:59:44.557] kernel read area: addr: 000CDC00 len: 0400
[04:59:44.777] kernel read area: addr: 000CE000 len: 0400
[04:59:44.977] kernel read area: addr: 000CE400 len: 0400
[04:59:45.197] kernel read area: addr: 000CE800 len: 0400
[04:59:45.398] kernel read area: addr: 000CEC00 len: 0400
[04:59:45.628] kernel read area: addr: 000CF000 len: 0400
[04:59:45.838] kernel read area: addr: 000CF400 len: 0400
[04:59:46.049] kernel read area: addr: 000CF800 len: 0400
[04:59:46.279] kernel read area: addr: 000CFC00 len: 0400
[04:59:46.499] kernel read area: addr: 000D0000 len: 0400
[04:59:46.710] kernel read area: addr: 000D0400 len: 0400
[04:59:46.930] kernel read area: addr: 000D0800 len: 0400
[04:59:47.140] kernel read area: addr: 000D0C00 len: 0400
[04:59:47.351] kernel read area: addr: 000D1000 len: 0400
[04:59:47.561] kernel read area: addr: 000D1400 len: 0400
[04:59:47.781] kernel read area: addr: 000D1800 len: 0400
[04:59:47.981] kernel read area: addr: 000D1C00 len: 0400
[04:59:48.202] kernel read area: addr: 000D2000 len: 0400
[04:59:48.402] kernel read area: addr: 000D2400 len: 0400
[04:59:48.602] kernel read area: addr: 000D2800 len: 0400
[04:59:48.823] kernel read area: addr: 000D2C00 len: 0400
[04:59:49.033] kernel read area: addr: 000D3000 len: 0400
[04:59:49.243] kernel read area: addr: 000D3400 len: 0400
[04:59:50.205] kernel read area: addr: 000DB800 len: 0400
[04:59:50.415] kernel read area: addr: 000DBC00 len: 0400
[04:59:50.625] kernel read area: addr: 000DC000 len: 0400
[04:59:50.816] kernel read area: addr: 000DC400 len: 0400
[04:59:51.046] kernel read area: addr: 000DC800 len: 0400
[04:59:51.256] kernel read area: addr: 000DCC00 len: 0400
[04:59:51.677] kernel read area: addr: 000DF800 len: 0400
[04:59:54.751] kernel read area: addr: 000FF800 len: 0400
[04:59:54.992] kernel read area: addr: 000FFC00 len: 0400
Keener2.5
