zlancerman wrote:This is interesting to see since I'll be doing something similar next month (going from 240cc to 440cc). Someone told me that the injector scaling should go opposite, meaning the larger the replacement injector, the smaller the number you should enter. This is due to the fact that the car is meant to idle with the stock injectors. When you double your injector size, you also double the amount of gas that enters the engine under the same pulse width since the car thinks its the stock injector. To compensate for that, you cut the scaling factor in half. So theoretically, if you double your injector size, you should half the injector scaling number. Try that out and see what happens. So set your injector scaling factor to say 115 or 110. Let us know what happens.
I’m not sure I would agree with that. I have the 3.0 L v-6 and I used the ECU Flash to tune. I recently replaced my 210cc injectors with larger 310cc and initially scaled them in the flash as '310'.
don't you have a 1D map in your Mitsu to indicate the size of the injectors?
Yes, we have that 1D map. Even though, I don't think it is a perfect one-to-one ratio with the cc size of the injector, I believe that number has got to be close.
When I put the number '310' in, the car idled fine, but my long-term fuel trim were way positive during idle. With my 210cc injectors, I was always a bit negative. So, why would the ECU need to add fuel for larger injectors? Because the scaling, the way I believe it works, is doing its job. It is narrowing the pulse width of the larger injectors to the point where I had positive LTFTs. I change the scaling number to "305" and my LTFT got better. I'm now going to try "295" and see how that lands.
Guys, I can't say I know for sure... and this thread has made my wonder if I scaled the injectors properly... but to scale 550cc injectors to a number of '120', doesn't make sense. I just recall before us 3g eclipse owners had the flash, there were a lot of attempt to prevent the idle from getting too rich during idle (the injector scale on our car was still 220 and people were put the 310 and the 440 injectors on).
3gturbo, I'd try to make incremental changes like go to '530' or '520' and see how you load and LTFTs work out. I’m still learning myself and let me know if my thought process is incorrect.
