Newb just starting+unnable to read downloded files
Postby Easyrider » Tue Aug 29, 2006 4:57 am
Hi.Ive downloaded ecuflash and explorer and have downloaded some of the files that people have posted of their ecu data, but i cant seem to view any of the data-is there anything else that i need to view them,or am i being a complete ar#e???
Ive allready been searching for info but as of now im still stuck :oops:
Any help is much appreciated.
Gary.
Easyrider
Postby m3n0ch3 » Tue Aug 29, 2006 6:35 am
Hi Gary,
All you need to do is create the xml file.
you need xmlwrite to do so.
once you have a rom, let's say: A4SGA00C.hex
copy it into the xmlwrite directory
start xmlwrite and put in the call id A4SGA00C
tell it for which program you want the xml file and it'll create it
copy the file (xml) into the definition directory of the application and you should now be able to read your map
Phil
m3n0ch3
Postby 06rexwagon » Tue Aug 29, 2006 7:28 am
...or you could just use enginuity from enginuity.org. It already has most of the ecu definitions built in.
06rexwagon
Postby Easyrider » Tue Aug 29, 2006 2:09 pm
Thanks, thats been a great help- After much headscratching ive eventually got Enginuity up and running (i didnt reallise that i needed java to run it :oops: ) ,just got to get me a a usb cable to connect up now- i feel this is when the real head scratching starts-but hey, we've all got to start somewhere :D
Easyrider
