Help creating ecu flash xml def for my04 A4TF520F
Postby ant24 » Mon Aug 21, 2006 9:31 am
How do you go about creating an xml def that isnt included in xml write. I can open and edit the A4TF520F rom in enginuity but dont have a def for ecuflash.
ant24
Postby JRSCCivic98 » Tue Aug 22, 2006 5:39 am
Grab the latest version of ecuEdit and use that. The new 2.2 version has a new feature to convert Enginuity xml defs to ecuEdit ones. I don't know how that works because I've never had to use it, but that's going to be your simplest method. Other way would be to manually change the xml format on your Enginuity def to match those needed by ecuEdit.
Postby ant24 » Wed Aug 23, 2006 9:28 am
well what I needed was an xml for ecuflash but I guess I'll just edit/tune in enginuity and only flash with ecuflash.
ant24
Re: Help creating ecu flash xml def for my04 A4TF520F
Postby Easyrider » Tue Aug 29, 2006 2:59 pm
ant24 wrote:How do you go about creating an xml def that isnt included in xml write. I can open and edit the A4TF520F rom in enginuity but dont have a def for ecuflash.
Im new to this also-do you mean that you can see all the data/parameters/make changes in Enginuity, but if you open the same file in ecuflash you cant see them(apart from the ROM info)???
If that is the case-can you still flash the parameters in this way???
Gary.
Easyrider
Postby west_minist » Tue Aug 29, 2006 4:02 pm
I think this is it.
Here you go.
A4TF520F.xml
(10.83 KiB) Downloaded 780 times
