Evo VI RSII Reflash Connector?
Postby R. Mutt » Wed Jul 19, 2006 3:22 pm
Where exactly is the "reflash" connector port for evo 6?
I am seeing the OBD-II port underneath the steering wheel, but there is no white reflash connector next to it.
With just the Tactrix OBD-II cable connector plugged I was unable to download the stock ROM and received the following error:
"H8/500 processors are not yet supported!"
Is this a problem with the software or the 1.3M Cable? It's an Evo 6 RSII. I understand the software is not yet compatible with the CP9A go down, but when this is resolved will the cable be a problem as well?
R. Mutt
Postby R. Mutt » Thu Jul 20, 2006 4:20 pm
No reply but 22 views :?:
R. Mutt
Postby 05GarnetLGT » Fri Jul 21, 2006 7:40 am
they didnt sell the EVO6 in the US, so, nobody here has em lol.
edit:
how the hell do YOU have one?
05GarnetLGT
Postby R. Mutt » Fri Jul 21, 2006 12:42 pm
I travel between NY and Trinidad...we have 10 RHD RSII's in the country, one of them being my friend's own. I bought a couple t1.3M cables cables for him and another friend with a CP9A GSR but we can't locate the reflash ports on either.
R. Mutt
Postby Michal_6 » Sat Jul 29, 2006 10:01 am
mayby someone could make a photo of reflash connector to show it location :?: I didn't find it either.
R. Mutt what kind of processor do you have in your ECU ? I have MH7203FA in my Evo 6.5 TM
Michal_6
Postby Sanctifier » Thu Aug 03, 2006 1:48 pm
My RS2 is the one Mutt is talking about above...
GTODesign wrote:E5/6 does have the second init connector but the E4 doesn't.
E5/6 uses a different MCu to E7/8 which may explain why you are having problems with your OBDII loggers.
GTO I'm afraid that neither the E6 GSR or E6 RS2 (my model) have the second re-flash socket.
I posted the following in another thread. I hope you can help...
I am trying to initialize my Evo 6 RS2 ECU with the Tactrix OpenPort 1.3M cable.
I read this in another thread. Not sure if it also applies to my problem...
cboles wrote:...The new Mitsubishi cable needs and uses these drivers, (sic~ FT2DXX drivers/DLL) but since
there is no other software which works with that cable yet, there are no legacy support issues.
Unlike the Evo 7-9 models, the Evo 6 RS2 has no additional socket alongside the
OBDII port under the dashboard.
I'm looking for an alternative connector or wire that can be used on the
1999-2000 Evo 6 RS2s (with Immobilizer) for initialization to reflash the ECU.
I know that the Evo 6 software is still a work-in-progress... but this seems
to be more of a hardware issue that will have to be addressed anyway.
At the moment any attempt to initialize results in this error message...
Any help or advice appreciated.
Sanctifier
