Where do I find the case ID and Internal ID on my EVO ECU?
Postby allcdsrus » Sun Jun 18, 2006 2:09 pm
Im lead to believe its under the dash, but can anyone indicate where exaclty. I see the Plugs I connect to but there is no labelling there but there is another large white section at the opposite side.
Thanks in advance
AC
allcdsrus
Postby SilverBack » Mon Jun 19, 2006 10:18 am
If you mean, where is the engine ECU...?
Behind the glovebox on the 9.
Open glovebox.
Find peg thingy, top right hand corner, slide and remove.
Push the left hand side in, to push passed that stop peg and drop the glovebox down to access behind to locate ECU
SilverBack
Postby allcdsrus » Mon Jun 19, 2006 11:18 am
Thanks for the response
I believe my code is MR 975815
Does anyone have any def's for this?
Many thanks
AC
allcdsrus
Postby burgers » Fri Jun 23, 2006 11:47 pm
Hi
If you read the map and upload it to the Mistubishi ROM files part of this web site, I'm sure someone will have a look at it for you. What model and market is the car?
MB
burgers
Postby YP » Sat Jun 24, 2006 3:04 am
allcdsrus wrote:Thanks for the response
Many thanks
AC
:!: Attention! MR975815 is a PASSANGER AIR BAG MODULE for CS2-CS5 Lancer JDM. Don't touch it.
YP
Postby allcdsrus » Sat Jun 24, 2006 4:55 am
thanks for the reply, I was informed to look behind the glove box to find the case id for my ecu...that MR code is the only one I could see.
Doh...thats why the code made no sense :-)
allcdsrus
Postby burgers » Sat Jun 24, 2006 7:38 am
Hi
You have to take the ECU out to see the case number. If you can see all the wires going into the ECU you should be able to see where the ECU is held in, on my car there are 3 M6 bolts.
You realy need to take the glove box out, the stopper nearest to the centre of the car pops outand then you can get the golve box out.
MB
burgers
Took out my ECU...
Postby allcdsrus » Sun Jun 25, 2006 2:05 pm
And on the case it had the following
MN132750
E6T34877 H 3304
allcdsrus
