by cboles » Sun May 28, 2006 9:33 am
AF426-xxxx is a number written on case, and not stored anywhere in the ROM itself. I believe it represents a combination of what hardware revision is inside along with the ROM version (e.g. A4SGE01C). Obviously, you can change the ROM inside, and the printing on the case is not going to change, so the case ID is only useful if the ECU has not been reflashed by anyone (including the dealer).
Programs like EcuExplorer and EcuFlash have databases that map between a 5-byte SSM ID (returned over SSM), the ROM version, and the case ID. If the ROM has been changed, these programs can report a case ID that doesn't match yours. Also keep in mind that this case ID data is gathered from users - who may report information incorrectly - particularly if their ECU has been reflashed.
