need help 2008 mitsubishi eclipse
Postby hwald » Thu Oct 13, 2011 8:20 pm
i just received my openport 2 cable from tactrix and having problems reading the ecu on my 08 eclipse 4G69 AT.
this is the log file i'm getting on ecuflash:
13:16:09.671] J2534 API Version: 04.04
[13:16:09.671] J2534 DLL Version: 1.00.3210 Nov 22 2010 23:18:50
[13:16:09.671] Device Firmware Version: 1.11.3209
[13:16:09.671] Device Serial Number: TA*tTMA1
[13:16:11.234] sending init sequence 1 (0001)
[13:16:14.437] sending init sequence 1 (0003)
[13:16:17.640] sending init sequence 1 (FFFF)
[13:16:20.343] no response to any known code
[13:16:20.343] interface close
hwald
Re: need help 2008 mitsubishi eclipse
Postby radsdau » Sun Oct 16, 2011 5:14 pm
Try ECU Unlocker (search forum).
Are you sure it doesn't use one of the CAN hookup methods?
