Support for tiburons
Postby pewp » Mon May 08, 2006 8:13 am
i read about this on the the evolutionm.net forums and a friend with an sti also told me about you guys. i sent mail to mynesperformance regarding this as well. i'm not really sure who i need to contact, but i'm just wanting to find out what the tiburon community needs to do in order to get this software for our cars (along with the proper hardware).
i made a post on the newtiburon.com forums about you guys to see what kind of interest there is. i will also be trying to talk to a vendor to see if they are interested in working with this software.
http://www.newtiburon.com/forums/showth ... ost1264078
that is a link to the thread i made on that site.
a little info about my car. i have a 2003 hyundai tiburon v6 with a vortech v-5 g trim supercharger with about 315whp. all i have for tuning is a wideband, odbii scanning software, and safcii.
pewp
Postby Freon » Mon May 08, 2006 8:51 am
I think step 1 is to crack the ECU open and see what processor and other primary ICs is has, see if there are datasheets available on them. I believe the ECU package is produced by Seimens, while most of the work here is on Denso packages, so it may be a very different setup.
It is unfortunate there is no one with a flash program for the Tiburon. REAL used to, but they're gone now. I believe they literally desoldered the processor. I have to assume Hyundai has a way to flash the ECU through the OBD port. They have TSBs that require ECU reprogramming just like everyone else.
Postby pewp » Mon May 08, 2006 9:05 am
i realize they wouldn't be the same, but it's worth a shot to see if it can be done.
pewp
Postby mellowmarshall » Mon May 08, 2006 9:46 am
here's to hoping we can get the ECU cracked, and finally get complete control of our vvt!
mellowmarshall
Postby cboles » Mon May 08, 2006 10:00 am
If someone has a spare ECU to loan, I'll be happy to check it out.
Postby 03silvertiburon » Mon May 08, 2006 10:12 am
I would definately be interested in this; I will try to locate a spare ECU or even buy one if I can find one at a decent price (I have no idea what they even cost to tell you the truth). I will keep you posted. I am hoping we can get this rolling as I need a tune badly because my car is running rich; plus I am wanting cams...which REAL stole some of my $$ for! So they are out of the question...
03silvertiburon
Postby pewp » Mon May 08, 2006 10:13 am
give me an address to mail it to... i have one that is from a sonata, but should work the same as our tiburons...
pewp
Postby TiburonRaven » Mon May 08, 2006 2:41 pm
i'm definitely interested too, i have 2.0 2003 year tib . a bud of mine is going to order evo9 cable , we'll try , if will be able to download my .bin , i'll make contact. i
TiburonRaven
Postby mellowmarshall » Thu May 18, 2006 7:27 am
dont forget about us, colby if you happen to read this we need your address to mail the ecu
mellowmarshall
Postby TiburonRaven » Wed Jun 07, 2006 4:16 am
are there any news on our problem of the century ?:)
TiburonRaven
Postby TiburonRaven » Sun Aug 13, 2006 11:13 am
tiburon community dying to see any progress. dying to help with time and money. regards
TiburonRaven
Postby bing » Sun Aug 13, 2006 4:42 pm
Tiberon V6 uses a siemens ecu with a infineon C167-CR microprocessor
The early variant ecu has a 29F400BB, the latter (september 04+) 29F800B.
The ecu flash can only be read via diagnostics with a program uploaded to ram just like the subaru, as the factory code only facilitates programming.
The ecu speaks Kwp2000 protocol on the K-line.
Attached is a read from a tiberon flash for disassembly ;)
best regards,
bing
Hyundai Tiburon (Original) - 652048.rar
(99.53 KiB) Downloaded 1181 times
bing
Postby Freon » Tue Sep 26, 2006 9:07 pm
Hey! How'd I miss this.
I think I found the timing map already. :)
Postby t-power » Mon Oct 02, 2006 4:29 am
2.0 Hyundai
Part39105-23270_Siemens5WY1616A_Hyundai_Coupe_20L_16v.zip
(151.13 KiB) Downloaded 1267 times
t-power
Postby t-power » Mon Oct 02, 2006 4:31 am
Freon wrote:Hey! How'd I miss this.
9D4C :D
t-power
