Need a part for a 1.3 cable
Thu Mar 24, 2011 9:35 am
by 06Black
Hello all!
Ive got an older 1.3 cable, but she works perfectly fine for what i need. however, i need the "other" plug that required for flashing on a Mitsubishi.
i dont see this part in the store, is it possible to get?
any suggestions?
thanks!
Bryan-
Re: Need a part for a 1.3 cable
Fri Mar 25, 2011 11:12 am
by 06Black
bump! any one? help!!!
edit-
i should say that i found this-
http://www.tactrix.com/index.php?page=s ... &Itemid=53however, its listed as for use with 2.0 cable only and it looks nothing like the one i used to have.
what i need looks allot like the subi reflash connectors, its what you use along with the Tactrix cable.
Sun Mar 27, 2011 4:32 pm
by radsdau
You can use that connector, and join the programming voltage output on the OP1.3 cable to the 2.5mm plug using an alligator clip or similar.
Tue Mar 29, 2011 6:35 am
by 06Black
will that really work? i mean has it been proven at least?
i wish i could just get another plug like i had.
thanks for the advice!
Tue Mar 29, 2011 9:50 pm
by radsdau
Yeah sure, that should work. Double check connections with a multimeter if you think there's an issue.
Or crimp one of the old-style bullet plugs onto the end (or make up a 2.5mm socket-bullet male adapter cable if you don't want to chop the Tactrix cable up). There's only a single connection used on that plug, not much to go wrong.
