02 forester ecu question
question for folks on here....
any reason the 02 forester (and similar) havent been cracked? i mean, im not a good programmer at all otherwise id have looked into it for a few reasons.
speed density. no maf makes me happy. i spend alot of time tinkering with old 80's turbo chryslers so speed density seems easier to me than a maf. i know the ecu is 1-bar as it sits but i wouldnt think scaling the tables that reference map would be all that hard to enable turbo operation.
built in wideband controller. i was surprised when i looked down in the engine bay and saw a bosch lsu4 wideband sensor. that would make tuning a snap i would think if the logs from the ecu contained wideband data.
the engine attached to these ecu's has no tumble generators.
the engine attached to these ecus has easy to get top feed injectors.
just curious i suppose.
thanks
Brian
thanks
Brian
