I'm running with my EVOX'08 on a boost from 22PSI at max torque and it tapers to 18.9 @ 6500.
I think it has a lack of power above 6500 so I've made several logs with VCDS and noticed the next thing:
When I do a pull in any gear at full throttle, the throttle goes from 96% to 60% above 6500RPM. How to avoid this?
No trottle map makes such a change at high rpm
