Problem flashing Evo 6, help!
Postby BhpTuner » Sun Dec 20, 2009 3:12 am
Hi all, had a problem flashing a mod to an Evo 6, using ecuflash the test write is ok but when I actually write to ecu I get an error, attached below, I can write the original back no problem.
Anybody have any ideas or advice?
Chris
[16:28:52.616] J2534 API Version: 04.04
[16:28:52.616] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[16:28:52.616] Device Firmware Version: 1.07.2597
[16:28:55.610] sending init sequence 2
[16:28:55.690] got 0x13 response instead of 0x11
[16:28:55.690] sending init sequence 3
[16:28:56.141] entering bootloader
[16:28:56.221] sending kernel size (2029)
[16:28:56.281] sending kernel load address (0x0000F000)
[16:28:56.291] uploading kernel
[16:28:56.622] verifying kernel checksum response
[16:28:56.622] kernel valid
[16:28:56.822] kernel get version
[16:28:56.882] kernel version is : OpenEcu Mitsubishi H8/539F Kernel V1.06
[16:28:56.882] reading kernel comm buffer size
[16:28:56.942] comm buffer size set to 256
[16:28:56.942] reading kernel flash buffer size
[16:28:56.952] flash buffer size set to 1024
[16:28:57.112] -- flashing image to ECU memory --
[16:28:57.513] -- comparing ECU flash memory pages to image file --
[16:28:57.513] seg start len ecu CRC32 img CRC32 same?
[16:28:57.663] LB7 00010000 00003000 20B88DCE 638A3E14 NO
[16:28:57.763] SB0 00013000 00000200 BD7BC39F BD7BC39F YES
[16:28:57.823] SB1 00013200 00000200 BD7BC39F BD7BC39F YES
[16:28:57.884] SB2 00013400 00000200 BD7BC39F BD7BC39F YES
[16:28:57.954] SB3 00013600 00000200 BD7BC39F BD7BC39F YES
[16:28:58.014] SB4 00013800 00000200 BD7BC39F BD7BC39F YES
[16:28:58.074] SB5 00013A00 00000200 BD7BC39F BD7BC39F YES
[16:28:58.144] SB6 00013C00 00000200 BD7BC39F BD7BC39F YES
[16:28:58.204] SB7 00013E00 00000200 BD7BC39F BD7BC39F YES
[16:28:58.464] LB6 00014000 00004000 EA3E3443 EA3E3443 YES
[16:28:58.665] LB5 00018000 00004000 BEF6372A BEF6372A YES
[16:28:58.865] LB4 0001C000 00004000 690B37D3 690B37D3 YES
[16:28:59.065] LB3 00020000 00004000 824D955A 824D955A YES
[16:28:59.266] LB2 00024000 00004000 2A89DA00 2A89DA00 YES
[16:28:59.476] LB1 00028000 00004000 6A780468 6A780468 YES
[16:28:59.676] LB0 0002C000 00004000 64438855 64438855 YES
[16:28:59.676] kernel flash enable
[16:28:59.736] kernel blank flash page: addr: 00010000
[16:29:14.798] WARNING: failed to erase page at 00010000!
[16:29:14.798] kernel flash disable
[16:29:16.901] interface close
BhpTuner
Re: Problem flashing Evo 6, help!
Postby todd-w » Sun Dec 20, 2009 7:09 am
its prob 7203f processor it cant be flashed at the moment but 7202f can , take the cover of the ecu and look at the processor number. what 6 is it in 7203 usually found in 6 makinen. 6 gsr ecu mr320403 are 7202f and can be flashed , all evo 5 ecu (md356472/md360216) are aswell
todd-w
Postby todd-w » Sun Dec 20, 2009 7:23 am
pic mh 7203f not flashable
pic mh 7202f flashable
todd-w
Postby BhpTuner » Sun Dec 20, 2009 9:59 am
Ok thanks for that, I will check.
Strange that the original will write back, or is it because there are no changes to make so it actually isn't writing anything, just need to get my head round it??
What would be the correct solution now, a newer ecu, maybe from a 7, would it be just plug and go?
Chris
BhpTuner
Postby Bruce Willis » Sun Dec 20, 2009 2:12 pm
Yes, in fact, if you try to write the modified firmware, the kernel will fall into error when you try to erase the sector, which found the changes. But at the same operation will be thrown out, on this block since you can not sew on the old one.
Bruce Willis
Postby MattS00 » Sun Dec 20, 2009 10:54 pm
I cannot tell from the log, but are you using an OP 2.0 cable? The flash will not work without a OP 2.0 cable. Also, if I remember correctly the H8/539F memory model is for the MH7203 processor and the H8/539 memory model is for the MH7202 processor. I suggest checking the number on the processor board first.
MattS00
Postby todd-w » Mon Dec 21, 2009 12:48 pm
you can use evo5/6 with 7202 processor or 7 ecu with a few wire swaps easy enough to do.
BhpTuner wrote:Ok thanks for that, I will check.
Chris
todd-w
Postby BhpTuner » Wed Dec 30, 2009 3:47 am
MattS00 wrote:I cannot tell from the log, but are you using an OP 2.0 cable? The flash will not work without a OP 2.0 cable. Also, if I remember correctly the H8/539F memory model is for the MH7203 processor and the H8/539 memory model is for the MH7202 processor. I suggest checking the number on the processor board first.
Thanks for all the replies, there is light at the end of the tunnel now.
Yes I have OP2.0, looks like I selected the wrong car when reading, should've selected MH7203F, will have to wait til I get car back and try again
BhpTuner
