Guys, need help w/ Lancer Evolution 7 ECU
Postby gwapio » Tue Oct 20, 2009 7:00 am
Hi, good day. Me and my friend just came from the dyno shop today hoping we could tune his EVO 7. when the tuner checked the ecu, he told us that he cant reflash the ECU because its JDM. I think he's using the program "ECU FLASH" but i'm not so sure. Here is the details.. (Mitsubishi Lancer Evolution 7/ Manufacture date 2001/ JDM ECU). Hope you guys can help us with it. thanks a lot. more power.
gwapio
Re: Guys, need help w/ Lancer Evolution 7 ECU
Postby todd-w » Tue Oct 20, 2009 8:56 am
nonsense ,you can flash all evo 7 ecus with ecuflash what exactly was the problem , def file ???. its prob 98640014 .
98640014.xml
(16.83 KiB) Downloaded 901 times
todd-w
Postby todd-w » Tue Oct 20, 2009 9:16 am
alternatively he can use a modified tephra 90550001 ralliart rom , has some nice extras .
todd-w
Postby gwapio » Wed Oct 21, 2009 7:38 am
he told me he doesnt have the file or software to tune the JDM ECU of the evo 7. what are the other options that you can share/suggest sir?
gwapio
Postby gwapio » Wed Oct 21, 2009 7:40 am
todd-w wrote:alternatively he can use a modified tephra 90550001 ralliart rom , has some nice extras .
can you share of send me that type of file sir? if you have, that would be very helpful. thank you sir.
gwapio
Postby gwapio » Wed Oct 21, 2009 7:53 am
todd-w wrote:nonsense ,you can flash all evo 7 ecus with ecuflash what exactly was the problem , def file ???. its prob 98640014 .
he just told me sir that unlike the ECU of a EUDM or the australian EVO7s, the Japan or JDM ECUs cant be reflashed because he only has the files for EUDM EVO7s. Our car is from japan that is why its ECU is JDM. What do you think should i do sir? badly need your help. thanks in advance.
gwapio
Postby todd-w » Wed Oct 21, 2009 9:50 am
Is he using ecuflash , we fitted evo7 jdm ecu into evo3/ 4/5/6 and never had a problem . Can he download the existing rom and e mail it to me then il send him the def file .
todd-w
Postby gwapio » Thu Oct 22, 2009 7:51 am
todd-w wrote:Is he using ecuflash , we fitted evo7 jdm ecu into evo3/ 4/5/6 and never had a problem . Can he download the existing rom and e mail it to me then il send him the def file .
ok sir, will do.. thanks..
gwapio
Postby leong1 » Wed Dec 16, 2009 11:02 pm
hi todd-w ,gwapio nice too meet you guy ..
i have one of my old 1.8 gsr turbo 1996 and my wiring is run evo2 .
i plan to do is swap or change my wiring to evo 5,6,7 and ecu rom to my car .
but i scare won't work ..
any body do this swap before and can tune with ecu reflash ?
leong1
Postby leong1 » Thu Dec 17, 2009 4:04 am
i find evo 3 map
FUEL table NUMBER 1 for EVO III GSR!
(start byte 717C)
8d 80 80 80 80 80 80 80 80 84 86 8c 94 94
8d 80 80 80 80 80 80 80 80 86 88 8C 96 96
8d 80 80 80 80 80 80 80 84 88 8a 8e 9a 9a
8d 80 80 80 80 80 80 80 86 88 90 98 a0 a0
8d 80 80 80 80 80 80 80 88 88 96 a0 a4 ab
96 80 80 80 80 80 81 88 90 92 9b a4 a8 ae
9a 8c 80 80 80 81 82 8a 94 9c a4 a8 ad b3
9a 8c 8c 8c 8d 8e 90 94 9a a0 a5 ab b0 b5
9a 8c 8c 8c 8e 8e 90 98 9e a3 a9 ad b5 b8
9a 8c 8c 8c 8e 90 98 9d a2 a8 ad b4 ba bf
9a 8c 8c 8c 90 98 a2 a7 aa b0 ba bd c0 c4
9a 8c 8c 8c 90 99 a3 a9 ae b2 bd c5 c7 ca
9a 8c 8c 8c 90 9a a4 ab b1 b5 c0 c8 ca cf (end byte 7231)
Fuel table NUMBER 2:
(start byte 7232)
8d 80 80 80 80 80 80 80 80 86 88 8c 96 96
96 80 80 80 80 80 80 88 90 94 9d a4 aa b0
9a 94 94 80 80 80 84 8a 96 9c a4 a8 af b6
9a 94 94 8c 8d 8e 94 9a 9e a2 a8 b0 b5 b8
9a 94 94 90 90 90 9a a0 a8 a8 b0 b2 ba bd
9a 94 94 96 9e a4 ae b0 b5 b7 be c3 c3 c3
9a 94 94 96 a0 aa b8 bb c0 c6 c8 cc cf cf
9a 94 94 96 a0 aa b8 bb c4 ca cb cf d0 d0
9a 94 94 96 a0 aa b8 bb c4 ca cb cf d0 d0 (end byte 72F4)
Timing table:
start byte 7568
08 08 08 08 10 18 19 1a 1c 1d 1d 1d 1f 1f 1f 20 20 20
etc...etc...
etc....etc...
Rev limiter code (byte 43a4 / 43a5):
1c 01 cb 24 05
3750000/459 = 8169RPM STOCK REV LIMITER!
Speed limiter (byte 5257/5259):
5257: 86 5C L5257 LDAA #$005C
5259: 8F XGDX
143MPH speed limiter!
FUEL CUT (byte 10F6):
10F5: C1 B8 L10F5 CMPB #$00B8
No fuel cut edit B8 value with FF(255);
2G MAF CODE(wow what a surprise? )
WINK WINK!2G MAF CODE! L70FE
70FF: FF 85 85 STX L8585
7102: A8 B6 EORA $00B6,X
7104: BE C3 C8 LDS LC3C8
7107: CC D0 D4 LDD #$D0D4
710A: D7 DA STAB L00DA
710C: DC E3 L710C LDD L00E3
710E: E6 E8 LDAB $00E8,X
7110: EB EA ADDB $00EA,X
7112: EA E8 ORAB $00E8,X
7114: E7 7A STAB $007A,X
IDLE SPEED (Byte start:74D2)
Woot!woot! Got some idle speed?
74D2: 01 NOP
74D3: 01 NOP
74D4: 01 NOP
74D5: 6D 6D TST $006D,X
74D7: 7A 8C 9A DEC L8C9A
74DA: A6 AD LDAA $00AD,X
74DC: B3 5A 5A SUBD L5A5A
Stock idle speed for an evo III is : 872RPM ( "6D" x 8= 872)!!!
Octane maps:
Smells like octane maps to me
Number I MAP:
78CB: 0C CLC
78CC: 0D SEC
78CD: 0C CLC
78CE: 0E CLI
78CF: 12 18 1E 21 BRSET L0018,#$1E,L78F4
78D3: 21 21 BRN L78F6
78D5: 21 22 BRN L78F9
78D7: 24 25 BCC L78FE
78D9: 26 28 BNE L7903
78DB: 28 28
78DD: 0C CLC
78DE: 0D SEC
78DF: 0C CLC
78E0: 0E CLI
78E1: 12 18 1E 21 BRSET L0018,#$1E,L7906
78E5: 21 21 BRN L7908
78E7: 21 22 BRN L790B
78E9: 24 25 BCC L7910
78EB: 26 28 BNE L7915
78ED: 28 28 BVC L7917
leong1
