I have no plans to tune at this point, i just need to flash maps occasionally. maybe i'll start datalog in the future...
1st question: What is the process, using ecuFlash, to take a map off the car and to put one on? When i've seen it done, the car's key is turned on and off a couple of times before and after the map is flashed. what's the specific procedure in terms of having power to the ecu and flashing it?
i'm driving a 2005 Saabaru 2.5i. it's a wagon full of n/a fun.
another Q; I have a tactrix 1.3 cable, will that work with the newer ecuFlash programs that say they are for OP2.0?
thanks
-Andrew
