flash evo 5-6, mitsubishi h8 anyone try it yet?
Postby thumper1151 » Wed Feb 18, 2009 10:22 am
flash evo 5-6, mitsubishi h8 anyone try it yet? I know it says version 1.41 with the 2.0 cable will flash but has anyone tried it yet. I am looking to use this on my 98 eclipse but I just want to confirm that is is working properly now. also are the definitions included with ecuflash or has someone else figured them out? thanks
thumper1151
Re: flash evo 5-6, mitsubishi h8 anyone try it yet?
Postby radsdau » Wed Feb 18, 2009 3:24 pm
I tried reflashing and it failed trying to erase a flash block. Reads ok though.
Postby thumper1151 » Thu Feb 19, 2009 7:30 am
witch cable were you using and also what model were you flasing. I am verry interested because openecu states that version 1.41 works with the 2.0 cable.
thumper1151
Postby radsdau » Thu Feb 19, 2009 4:18 pm
OpenPort2 cable, EVO6 (actually 6.5) ECU.
Postby thumper1151 » Thu Feb 26, 2009 9:54 am
WHY DID COLBY POST THAT IT WORKS THEN?
thumper1151
Postby radsdau » Thu Feb 26, 2009 2:57 pm
thumper1151 wrote:WHY DID COLBY POST THAT IT WORKS THEN?
My guess is there is a difference with my ECU. If it works for him, it works for him.
