Subaru Outback - anyone have the experience?
PostPosted: Wed Sep 03, 2008 11:56 pm
by AlGontsov
Hello,
I'm try to read the Subaru Outback 2.5 2005 / 3.0 2006 and can't find any working module.
I connect the OBD2 plug and try all subau's variants and don't get any ECU response.
Maybe I need to use the small subaru connectors..? Under the Steering wheel only the plastic covers... Does any connectors which should I use or this vechile unsupported by 1.3 interface?..
I know some vechiles not listed, but has the same ECU as supported one's.
Thank you.
PostPosted: Thu Sep 04, 2008 3:44 pm
by radsdau
Check the ECU; it might be JECS. If so, there is no support for it with ECUFlash at present.
PostPosted: Fri Sep 05, 2008 7:24 am
by Jon [in CT]
You should be able to read those ECUs but you need to join together the two green test connectors on the passenger side.
http://www.scoobypedia.co.uk/index.php/ ... gToYourECU
PostPosted: Fri Sep 05, 2008 7:32 am
by AlGontsov
Thank you, i'll try to get some more info...
Where I can locate the ECU to check the label?
Jon [in CT]: have you read and write such cars..?
PostPosted: Thu Sep 25, 2008 8:06 am
by AlGontsov
All if fine, connectors onder the carpet of the passenger's feet,
There is the ROM, any defenitions avalilable..?
