In the Fuel column, which table do I use to add more fuel to the mix? Primary Open Loop or Primary open loop failsafe? I noticed the failsafe table has a wider rpm range of 7600 vs. 6800.
Also a higher number in the table means less fuel correct? (Red blocks make me think lean/aggressive....this is my brainfart)
Now with timing, I've noticed this new program has more to play with. I believe with enginuity, there was only base timing. So with RR I should stick with just base timing correct? Any advantages to tweaking the Timing advance Maximum table or the AVCS?
And obviously (in the base timing table) The smaller the number, the less aggressive the timing is correct? (such as green or blue instead of red blocks)
Thanks for the help. I'm really liking what I see from this new software. Nice changes from last year. I feel like I'm learning how to do all this stuff all over again
EDIT: ALSO with RomRaider, it doesn't seem to want to data log for me! I have everything connected, even selected COM5 instead of 3 but no luck
