Question about the test mode
Postby Zimin » Sun Apr 27, 2008 10:33 pm
Hello,
I want to read rom from my 02 EDM WRX, but always get an error.
[23:12:03.750] Using interface OpenPort 1.3 Universal TX27qQTjd4ecb4d9a1d6ae225e5755d6f5bcfdacbaef2534
[23:12:07.000] denso02_bootloader_cmd_start
[23:12:08.234] denso02_bootloader_cmd_start
[23:12:09.468] denso02_bootloader_cmd_start
[23:12:10.703] denso02_bootloader_cmd_start
[23:12:11.921] denso02_bootloader_cmd_start
[23:12:12.375] kernel get version
[23:12:12.718] interface close
(Green connectors connected, flashblock too (2003 type by the way), ECUFlash 1.34, Tacktrix 1.3, Ignition on then immediatly OK.)
I've searched all this forum but still can't read.
There is one thing I don't know.
With the green connectors connected there is no CEL flashing, and I don't hear radiator fan but when I'm starting the engine CEL is blinking all the time. Is it normal? Or I got some problems with entering test mode?
I got dispositif antivol which block something until I press two window raiser buttons. Once when we tried to connect the computer at maintenance. It could not view the car, until I pressed this buttons or started the engine.
So when I'm trying to read ROM I'm always holding this buttons.
Zimin
Postby Zimin » Mon Apr 28, 2008 10:11 am
I found how to disable dispositif antivol. And now I'm in true test mode and can read the ROM! I've read the ROM but when I press Save As... it can't save it and said in log can't open ROM to write...
Zimin
Postby Zimin » Sun May 04, 2008 8:05 pm
I don't know why but it couldn't write file onto my HDD. But when I've tried to save the rom onto USB Flash drive it was done!
Zimin
