i'm confused
i'm confused
Postby pezzar » Sun Mar 02, 2008 1:49 am
Hi
just recently joined the forum. I'm looking to make some mods to my 04 STI and an interesting thing caught my eye on the forums. A guy was asking about alternative maps and someone responded saying you would be best to pay someone to professionally tune the car.
If thats the case why the hell am i buying a cable and going to the trouble of getting, familiaring with the ecu software. I have a fair bit of experience with motor vehicles (engine building, mechanics,etc).
I read somewhere loading a map that is licenced by Ecutek is unusable, is that true or do they just tell you that to frighten you off using their maps. Also apparently once the ecu is modded and licenced it cant be then modded by the open source\tactrix route???
I know all engines are different, but my point is, surely if i can get a map from a car thats been modded with similar mods to myself this has got to be better than the bog standard map i have.
i Have a motorcycle with Dynojet's power commander system installed and dynojet actively issue alternative base maps on their website.
Someone i think is using this as a licence to print currency, we all know who they are :wink:
Regards
Pez
pezzar
Re: i'm confused
Postby Freon » Sun Mar 02, 2008 8:02 am
Some people who take the time can learn to tune their own cars. Not everyone is cut out for it. I tend to think those strong in math and science will be more successful than others.
Still others buy a cable and quickly start posting very newbie questions about how to "tune" their car. Stuff that if they actually demonstrated they were willing to spend time learning they could have easily found on their own. Sometimes when I see some questions that should be pretty simple asked by people trying to just jump into it I'll warn them with the sort of response you are talking about. If you can't figure out some of the easy stuff, you're probably not going to be successful. I'm not trying to be rude about it, but I think too many people jump in without realistic expectations about the time they will need to invest in just reading what is already out there and available.
Tuning your own car can be dangerous. You have to take responsibility for it yourself. Especially since no one is getting compensated to help you out and no one wants to be responsible for you blowing up your car.
I guess the point is, if you expect to be successful tuning your own car you need to show a lot of initiative and do a lot of research. If you have to ask about the basics and have to rely on an internet forum to answer every tuning question you're not going to be ready to tune your own car for another 3-4 years. I don't mean to discourage you, but you need to realize you need to spend a lot of time reading and researching car tuning in general. You need to be realistic about what it takes to tune a car. It is not something you learn to do over a weekend or two.
Here's a good start:
http://www.scoobypedia.co.uk/
http://freon.shackspace.com/car/ecu%20a ... books.html
You should buy all three books and read through them until you understand 90% of what is in them. This will take you a few weeks.
http://www.romraider.com/
Lots of great FAQs and countless threads in their forum that dig into tuning. My serious suggestion is to spend 2 months reading this forum and search a lot for things you want to know. Read entire long threads on different subjects.
The question about Ecutek stuff is moot. Ecutek has been locking out the ability to read ECUs that have been flashed by Ecutek software for over a year. So, just don't worry about it. Don't try to mix Ecutek, Cobb, and Openecu tools. Pick one and stick with it. It's not worth worrying about this. Just forget the Cobb and Ecutek stuff if you chose to use Openecu.
As for loading someone else's map from a car with similar mods, even minor mods can drastically screw up a tune. For instance, different boost control solenoids, or even just the restrictor pills or hose you use. It could be a different shape wastegate map. Different compensations. A different intake can throw things way off as well. Just one model year difference in the car may also mean different cylinder heads, requiring different tuning.
Re: i'm confused
Postby pezzar » Sun Mar 02, 2008 8:59 am
Freon wrote:Some people who take the time can learn to tune their own cars. Not everyone is cut out for it. I tend to think those strong in math and science will be more successful than others.
freon i completely understand what you are saying and fully agree. I am prepared to put in the legwork. I do have experience with engine tuning in fact my first tuning book was "tuning the BL A' series by David Vizard", i think you'll recognise that guys name. What is Cobb? I have the openecu software and also Romraider software too..from what i read openecu and romraider work in unison!
i have had a thorough read on scoobypedia
Freon wrote:http://www.romraider.com/
i guess there are some other tools i need, do you recommend the use of a wideband oxygen sensor? I fully understand the concept of controlling boost from inside the ecu and fuel and ignition maps, the 2 have to work in unison to provide the required settings for each throttle to rpm position, i also understand hexadecimal, binary and octal values too.
pezzar
Postby Freon » Mon Mar 03, 2008 3:50 pm
I would highly recommend a wideband. You cannot tune fuel without one.
Postby pezzar » Wed Mar 05, 2008 8:31 am
:wink: i found out what Cobb is
thanks for the advice i'll look at getting one of those.
so i just unplug my current lambda sensor and replace with the wideband is that correct?
Pez
pezzar
Postby Freon » Wed Mar 05, 2008 3:39 pm
No, you should not remove your factory sensors.
Postby pezzar » Thu Mar 06, 2008 2:15 pm
hi Freon
found some really useful videos on innovate motorsport website, but they recommend installing the bung into the exhaust downpipe before the cat and the sensor temp should not get over 900 degrees F. presumably placing the sensor in the down pipe just before the cat is ok as the hotest part is actually in the headers, is that correct. Also what is the maximum boost pressures you should aim to use around 1.6 bar is that the target i should be aiming for.
Regards
Pez
pezzar
