My factory ECU is an AF411 (auto transmission) 02 WRX unit with an A4SG900C CalID. Now, as far as I know, any of the AF41x ECUs (AF411, AF412, AF413) should be reflashable with the A4SG900C ROM and run just fine.
My question is, is it possible to take an AF42x (ie, AF423) manual ECU and flash it with the other ROM and have it run appropriately? That is, is the logic for AT vs. MT embedded in hardware, or is it simply a flash issue?
To complicate things, I've done an MT conversion on my AT car, so I've actually done some harness modifications to "convince" the ECU that it's in an MT vehicle.
I'm going to do some more IDA disassembly today and see if I can figure out where the ECU determines which vehicle it's in.
