Here is a list of part numbers of the components which constitute an 'up-to-date' NSM package:
- Code: Select all
Part Number Part Name Short Description
22771AA030 Select Monitor II Kit Base Kit
22783AA001 Select Monitor II Retro Cable Used on Vehicles Prior to 1998
24082AA080 Select Monitor II Retro Cartridge Used on Vehicles Prior to 1998
24082AA130RA Select Monitor II 1998-2000 Cartridge Used on Vehicles from 1998 to 2000
18482AA010RA Select Monitor II 2006 Cartridge Used on Vehicles from 2001 to 2006
24082AA290 Select Monitor II Immobilizer Cartridge Initializes ECM, BIU, Instrument Cluster
Note that SOA allows SPX Kent-Moore to sell the Immobilizer cartridge only to Subaru dealers.
There are three other parts that you want as part of your kit - the reprogramming cable, cartridge and jumper connectors kit - which Subaru supplied to dealers as part of the WWF-89 Service Campaign:
22775Z0C00 - Select Monitor Reprogramming Cable
24082X0A54 - Select Monitor Reprogramming Cartridge
24036AA010 - ECU Reprogramming Jumper Kit
I don't believe any of these last three parts are available frrom SPX Kent-Moore. The instructions to Subaru technicians describing how to perform a reflash on JECS ECMs with the NSM are included in the attachment below.
Subaru says that they've provided information to Equipment and Tools Institute (http://www.etools.org) which would allow a tool manufacturer to develop a device to intialize an ECM with the immoblizer. I think there's at least one member around here who has access the ETI's TEK-NET repository.
