quick quest. on lean spool
Postby nonschlont » Sun Jan 13, 2008 9:41 pm
This is my first post in this forum, so Hello to all! Please bare w/ me, Im a newb. lol
So I was trying to add lean spool to my ecuflash v.1.34. (evo ix) I got lean spool up, then changed the value as I read to 48, then tried to get lean spool disable, and was giving me probs... I tried on 9 base and parent... after playing w/ it... got it up, but wont let me change the value??? any ideas???
nonschlont
Postby C6ect.ect » Wed Jan 16, 2008 5:35 pm
You have the address for LS? What was the stock value in the cells?
My 04 VIII I believe is 1688 for the address. Start is 2500 and 4531 rpm units, start and stop, resp. (statrevuint16).
Interestingly, during a LS episode the AFRMAP is locked out to 132 or so, depending on baro I think, which ends up 0.5 to 1.5 points richer than stoich on the WB. I can directly change the AFRMAP duty by adjusting the 1D antilag table resulting in a fine tune of lean spool up to about 4500 rpm where it stops.
Does anyone know what the RPM units on the antilag table correspond to? The 1D table that starts with 600 and ends with 800 or so rpm units
C6ect.ect
