Cant fully load Enginuity on with Windows Vista???
Postby Easyrider » Mon Dec 24, 2007 1:36 am
Hi-Just brought a new laptop with Vista operating system on it-ive managed to get ecuflash on, but i cant get Enginuity to install.
Basically, i get to the point after agreeing to the terms&conditions,it starts to install but then get ---
java.io.FileNotFoundException:C:\ProgramFiles...................(access denied)
Any ideas on what i can do to get around this.
Thanks.
Easyrider
Postby Dweeb » Mon Dec 24, 2007 4:08 pm
do you have Java installed ?? www.java.com
try uninstalling Enginuity and then reboot, then install Enginuity again. Make sure the downloaded Enginuity package is OK. (just download it again) i have had that problem before. somehow it didn't download properly... and had a hard time installing.
worth a try anyway :wink:
oh, make sure to run as ADMIN or with Admin Privileges.
Dweeb
Postby Easyrider » Tue Dec 25, 2007 4:05 pm
Yes-Ive got java installed.
Ive just run the recovery disc to see if it would help , but have still got the same error coming up???
Easyrider
Postby Easyrider » Tue Dec 25, 2007 5:33 pm
Problem solved- just had to change the directory to Documents instead of ProgramFiles-all loaded on a treat.
Got another problem now-i am able to read the ecu data a treat with ecuflash, but cant seem to get the logger to work in Enginuity-keeps coming up with-
null, with protocol:SSM, and connection timeout: 2000ms
Anyone have any ideas???
Easyrider
Postby z38er » Fri Jan 18, 2008 1:47 am
Easyrider wrote:Problem solved- just had to change the directory to Documents instead of ProgramFiles-all loaded on a treat.
Hi there i have the same problem, when i try to start the logger, it only freez and i cant do anything :( :( :(
anyone have any problem like this
and btw i have a desktop with windows xp on it and it worked perfect...
and i have tried that run as admin but with no luck....... :(
and tried to turn off the firewall cuz sometimes it just keep on blocking but still nothing
z38er
