problems with ecu flash useing openport1.2
PostPosted: Wed Feb 08, 2006 7:43 pm
by fros_02_wrx
i cant get any program to read my ecu rom i get this everytime
[0.000] kernel flash disable
[3.172] denso02_bootloader_cmd_start
[3.062] denso02_bootloader_cmd_start
[3.063] denso02_bootloader_cmd_start
[3.047] denso02_bootloader_cmd_start
[2.266] unable to load kernel
am i supose to disconnect the white box and connect the green plug or both or neither?? im so freking confused! please help me befor i go insane
PostPosted: Wed Feb 08, 2006 8:13 pm
by qoncept
You want both connected and the key set to the on position to dump.
PostPosted: Wed Feb 08, 2006 8:15 pm
by fros_02_wrx
ok thats how i did it and i still have the same problem if you have yahoo messenger my ID is fros_02_wrx thanks for helping man
PostPosted: Wed Feb 08, 2006 8:16 pm
by intrawrx
I posted a reply on the Tari Forums.
PostPosted: Wed Feb 08, 2006 10:37 pm
by fros_02_wrx
thankis guys i got it all figure out now and its all working whats a good program to control the boost thru the stock ecu or is that possiable?
PostPosted: Mon Feb 20, 2006 10:35 pm
by radsdau
intrawrx, can you point me to this post please? Sorry, I couldn't find it. I'm having a similar problem with my 01/02 AF422.
fros_02_wrx, if you can help me out my telling me what you did to make it work, I'd be grateful too.
Thanks!
PostPosted: Mon Feb 20, 2006 11:07 pm
by fros_02_wrx
i used ECU flash, first open the program then connect to the OBDport thenconnect the green box under the dash,then click read from ecu then turn the ignition on and click ok
PostPosted: Wed Apr 05, 2006 6:29 am
by GotWRX03
I am having the same exact trouble with MY03 USDM. I've tried and tried, but no luck at all. :cry:
use 3.0.25
PostPosted: Wed Apr 05, 2006 6:39 pm
by Thumper
If using ECUExplorer, try using version 3.0.25 and not 3.0.6.
I couldn't get it to work with 3.0.6 but it works great with 3.0.25
