hello ,
i m beginer and i d like to know why they are two map for fueling , A and B ??
and how do you tune the failsafe map A and B ?
tahnks for all help
No one is 100% sure what goes into choosing A or B (there is actually a slider, it can be 50/50 combination, or 25/75, 70/30, etc). You can log the map slider value in Enguinity so you can tell which one is used, though.
Generally people just tune them the same.
The failsafe maps should be a "safer" setting. They're used when IAM falls low (there is a 1D map for when the switchover occurs). It should probably be richer.
