by merchgod » Sun Oct 07, 2007 9:40 am
When you select ‘read from ECU’ in Ecuflash (or the read icon), a list box will appear from which you must select the correct read method that corresponds to your vehicle. If the incorrect read method is chosen, the download will fail:
Ecuflash version 1.31 and newer:
2004 Subaru DBW models STi/FXT/LGT/Baja - USDM 04 STi/FXT, USDM 03/04 Baja, ADM/EDM/JDM 03/04 Forester/Legacy (including non-DBW models with 32-bit ECU)
2005–2007 Subaru DBW models WRX/STi - USDM 2005–2007 STi, USDM 06–07 WRX, ADM/EDM/JDM 06–07 WRX/STi
2005–2006 Subaru DBW models FXT/OBXT/LGT/Baja - USDM/ADM/EDM/JDM 2005–2006 Forester/Outback/Legacy/Baja, USDM/ADM/EDM/JDM 05–07 Impreza 2.5RS/2.5i, USDM 2006 B9 Tribeca
2002–2003 Subaru USDM Impreza WRX - USDM 2002–2003 WRX
2004–2005 Subaru USDM Impreza WRX - USDM 04–05 WRX ONLY
2001–2005 Subaru non-USDM Impreza WRX/STi - ADM/EDM/JDM 2001–2005 WRX/STi
Ecuflash version 1.30 and older:
2005–2006 Subaru DBW models WRX/STi/FXT/LGT/Baja - USDM 2005–2007 STi, USDM 06–07 WRX, USDM 05–07 Impreza NA, USDM 2006 B9 Tribeca, USDM/ADM/EDM/JDM 2005–2006 Legacy/Forester/Impreza NA/Outback/Baja,
2001–2003 Subaru Impreza WRX - USDM 2002–2003 WRX, ADM/EDM/JDM 2001–2005 WRX/STi
2004–2005 Subaru Impreza WRX - USDM 04–05 WRX ONLY
