Can you reset ECUTek ECUs using ecuExplorer
All,
A colleague has asked if I could read this fault codes and reset his ECU on a EDM MY05 WRX. I just want to double-check something with you...
His EcuTek was only done a couple of months ago and I want to check that resetting his ECU using good old ecuExplorer will be ok. I'm well out of touch with what EcuTek are doing these days so just checking they are not doing anything crazy in RAM that will be cleared when I reset the ECU.
Let me know what you think.
Regards,
Regards,
