by gteclass » Fri Sep 14, 2007 7:30 am
i think what he meant to ask is if there are any other brands that the cable could work for. The answer is that any 96 or newer car MUST be flashable through the OBD2 port as part of the emissions standard. The trick to this is that all OBD2 cars are flashable using an iso J2534 device. The problem with this is that each manufacturer has its own way of implementing these devices. Colby had said at one point that he was looking into it, but I think he has enough on his plate at the moment and it is probably well in the future.
