Is there anyway to disable the speed limiter or increase the limited speed by reprogramming the ECU? I understand there is a line from the speedometer to the ECU, which goes +5V once you hit the limited speed....
Spiider wrote:I think if you read a bit you will see you can easily defeat the speed limiter by adjusting the value at the offset. (Among many other values for tuning your car.)
I increased mine to 200km/hr, 180 was just a little low for me.
