Page 1 of 2
OpenPort and ECUflash for Mitsubishi
PostPosted: Tue Jan 31, 2006 12:49 pm
by GTODesign
What stage are the OpenPort and ECUflash at for Mitsubishi Evo 7, 8 and 9? Is there a beta version of the software and cable available to try?
PostPosted: Thu Feb 23, 2006 3:33 am
by GTODesign
Any info on this?
PostPosted: Thu Feb 23, 2006 7:58 am
by cboles
I'm in the process of having the mitsu cable manufactured now. It uses an additional connector and some different circuitry inside. When those are done, I'll release the software.
PostPosted: Thu Feb 23, 2006 8:03 am
by GTODesign
No worries. I assume the MH7202F kernel is still some time away, so I think the short term plan for my purposes will be to get some adaptor harnesses made and run an Evo 7/8 ECU in the Evo 4/5/6's. Do you know if Sumitomo also make the 3 plugs into the Mitsu ECU's?
PostPosted: Thu Feb 23, 2006 8:06 am
by cboles
Actually, that kernel would not take very long if I can find a H8/500 series compiler somewhere. I have ECUs to test it on.
PostPosted: Thu Feb 23, 2006 8:54 am
by GTODesign
Well I certainly can't find any freeware/shareware ones and I've been looking for sometime now. I can't even find any that have to be paid for, it seems everyone dropped support for the H8/500 in favour of the H8/300 ages ago. What happened to the guy that said he had an old Hitachi software disk with a DOS based compiler?
PostPosted: Thu Feb 23, 2006 10:09 am
by cboles
... no response on the thread or via PM :(
PostPosted: Fri Feb 24, 2006 11:55 am
by robcio
I found free cross assembler that supports h8/500:
http://john.ccac.rwth-aachen.de:8000/as/
and here is the list of all of the supported CPUs:
http://john.ccac.rwth-aachen.de:8000/as/cpulist.html
PostPosted: Fri Feb 24, 2006 1:36 pm
by Jon [in CT]
I believe cboles wanted to avoid using assembler and that's why he's looking for a C compiler.
PostPosted: Sun Feb 26, 2006 2:43 am
by evoman
cboles wrote:... no response on the thread or via PM :(
Sorry for my answer delay and disinformation about C-compiler.
It was noticed on CD-label about H8/300 & 500.
I seen the H8-soft on old Hitach CD closer and discovered that there is only H8/300 toolchain inside :cry:
May be http://www.kpitgnutools.com/ will be useful?
PostPosted: Mon Feb 27, 2006 9:05 am
by cboles
Interesting site - thanks. Looks like the only support H8/300 though. I'll have to go look - I assume the H8/300 instruction set / opcodes are different than the H8/500.
PostPosted: Fri Mar 03, 2006 9:32 am
by GTODesign
Colby,
Have you got a rough date for when the cables will be done? I should be finished breaking down the E7 and E7RA rom's in the next few days and I'm anxious to test my work.
On a seperate note, do you or anyone else have a rom image from an E7 EM9986 or RA57855711P1 ECU other than the ones listed on this site? I just want to compare like for like for determining the complete immobilizer code.
Many thanks
:D
PostPosted: Fri Mar 03, 2006 10:14 am
by cboles
They should be done one month from now. I'm sorry it's taking so long. Originally I had though that I could make them without making a PCB change from the Subaru OpenPort design. However, the Mitsubishis need a greater than battery voltage (say 15-18V) signal on their boot mode line to reliably put them in boot mode. Because of this, I changed the design to include a step-up voltage converter, which of course means building totally new hardware. I'm anxious to get all of this stuff out there - The new software supports so many more cars than my previous release...
PostPosted: Fri Apr 07, 2006 12:19 pm
by Nemis
cboles wrote:They should be done one month from now. ...
some news?
PostPosted: Mon Apr 10, 2006 2:17 pm
by jaytech
GTODesign wrote:Colby,
Many thanks
:D
The cables should be done shortly. The Mitsu init line connectors came in from Japan last week, and I sent them to Colby already. Also the immobilizer code on all 256K, and 512K ROMs are located at address 0X3FFCE-0X3FFCF, if that address area is 0XFF, then there is no immobilizer code in that ECU.
