Would the 1.3U work on AH970-5340?
Postby nabilsx » Fri Aug 03, 2007 1:22 am
Hello,
I need to know if the AH970-5340 would work with the 1.3U cable? I need to know which definition files to use with this ECU?
thank you
Nabilsx
nabilsx
Postby Jon [in CT] » Fri Aug 03, 2007 7:34 am
That ECU is from a Ver. 7 STi RA Type C. The OpenPort 1.3U cable can be used to read and reflash that ECU, but you'll also need the flash block connector (see http://www.tactrix.com/product_info.php?products_id=32).
http://www.Enginuity.org already has definitions for your ECU.
