2006 ED WRX Definitions
PostPosted: Thu Jun 28, 2007 7:33 pm
by ravenhil
Last night I was able to read the ECU from a EDM WRX (2.5 L) but it came out as gibberish rom.
I need the defnitions. Do you guys have it?
PostPosted: Fri Jun 29, 2007 5:47 am
by Jon [in CT]
Is your ROM listed at http://www.enginuity.org/Documentation/SupportedECUs? If so, then use Enginuity. If not, post a copy of it at http://www.enginuity.org/viewforum.php?f=8.
PostPosted: Sat Jun 30, 2007 10:42 am
by ravenhil
oh yes it is supported by Engunity. But is it safe to use Enginuity to edit the rom image and use OpenECU to flash that into the ecu? I suppose OpenECU can read and write ecus, but the rom image cannot be understood.
PostPosted: Sat Jun 30, 2007 2:43 pm
by merchgod
It doesn't matter whether or not Ecuflash has the maps correctly defined or not. You can flash with Ecuflash without modifying the tables in Ecuflash. You just have to make sure the .xml file corresponding to your cal id (ecuflash\rommetadata directory) has the correct flashmethod tag. It doesn't need to have any table definitions at all. For the 32bit ecus, use sti04 for 512kb rom and sti05 for a 1mb rom.
PostPosted: Sun Jul 01, 2007 3:06 am
by ravenhil
ok that's a relief. now I wish i studied c+c instead of genetics. just for yje fun of it, i located the definition for EDM 06 WRX A8DH200Y in enguinity and tried (unsuccessfully) to modify it into something that ecuflash can understand.
The xml file is below
</rom>
<romid>
<xmlid>CAL ID:A8DH200Y</xmlid>
<internalidaddress>2000</internalidaddress>
<internalidstring>A8DH200Y</internalidstring>
<caseid></caseid>
<make>Subaru</make>
<market>EDM</market>
<model>Impreza</model>
<submodel>WRX</submodel>
<year>06</year>
<flashmethod>sti05</flashmethod>
<memmodel>SH7058</memmodel>
<checksummodule>subarudbw</checksummodule>
</romid>
<include>sti05base</include>
<table name="Target Boost A" address="0xC0C54">
<table type="X" address="0xC0C44" elements="2"/>
<table type="Y" address="0xC0C4C" elements="2"/>
</table>
<table name="Target Boost B" address="0xC0CD8">
<table type="X" address="0xC0C8C" elements="2"/>
<table type="Y" address="0xC0CAC" elements="2"/>
</table>
<table name="Boost Limit (Fuel Cut)" address="0xC75FC" >
<table type="Y" address="0xC75E4" />
</table>
<table name="Low Speed Boost Compensation" address="0xC06D8" />
<table name="Low Speed Boost (Maximum Speed)" address="0xC06D4" />
<table name="Boost Compensation (Coolant Temp)" address="0xC0888" >
<table type="Y" address="0xC06E0" />
</table>
<table name="Initial Wastegate Duty A" address="0xC0A8C" sizex="2" sizey="2" userlevel="4" >
<table type="X" address="0xC0A7C" />
<table type="Y" address="0xC0A84" />
</table>
<table name="Initial Wastegate Duty B" address="0xC0AEC" sizey="8" >
<table type="X" address="0xC0AAC" />
<table type="Y" address="0xC0ACC" />
</table>
<table name="Max Wastegate Duty" address="0xC0BC4">
<table type="X" address="0xC0B84" />
<table type="Y" address="0xC0BA4" />
</table>
<table name="Initial Wastegate Duty Alternate (RPM)" address="0xC09AC" >
<table type="Y" address="0xC0998" />
</table>
<table name="Turbo Dynamics (Integral Positive)" address="0xC0954">
<table type="Y" address="0xC0930" />
</table>
<table name="Turbo Dynamics (Integral Negative)" address="0xC091C">
<table type="Y" address="0xC08F8" />
</table>
<table name="Turbo Dynamics (Proportional)" address="0xC08E4">
<table type="Y" address="0xC08C0" />
</table>
<table name="Wastegate Compensation A (Intake Temp)" address="0xC07A8" >
<table type="Y" address="0xC0768" />
</table>
<table name="Wastegate Compensation B (Intake Temp)" address="0xC0848" >
<table type="Y" address="0xC0808" />
</table>
<table name="Wastegate Compensation (Coolant Temp)" address="0xC0868" >
</table>
<table name="Wastegate Compensation (Atmosphere)" address="0xC0A4C">
<table type="X" address="0xC0A24" />
<table type="Y" address="0xC0A3C" />
</table>
<table name="Open Loop Fueling A (Primary)" address="0xC7AA0" sizex="2" sizey="2" userlevel="4" >
<table type="X" address="0xC7A90" />
<table type="Y" address="0xC7A98" />
</table>
<table name="Open Loop Fueling B (Primary)" address="0xC7B28">
<table type="X" address="0xC7AA4" />
<table type="Y" address="0xC7AE0" />
</table>
<table name="Open Loop Fueling A (Failsafe)" address="0xC7C48" sizex="2" sizey="2" userlevel="4">
<table type="X" address="0xC7C38" />
<table type="Y" address="0xC7C40" />
</table>
<table name="Open Loop Fueling B (Failsafe)" address="0xC7CD0">
<table type="X" address="0xC7C4C" />
<table type="Y" address="0xC7C88" />
</table>
<table name="Injector Latency" address="0xC765C">
<table type="Y" address="0xC7648" />
</table>
<table name="Injector Flow Scaling" address="0xC5E3C" />
<table name="Throttle Enrichment (Tip-in)" address="0xC7550">
<table type="Y" address="0xC7508" />
</table>
<table name="Throttle Enrichment Compensation (Boost Error)" address="0xC688C">
<table type="Y" address="0xC6868" />
</table>
<table name="Throttle Enrichment Compensation (Coolant Temp)" address="0xC7574">
<table type="Y" address="0xC6488" />
</table>
<table name="Warm-up Enrichment (Coolant Temp)" address="0xC7148">
</table>
<table name="Base Timing A" address="0xCA090" sizex="2" sizey="2" userlevel="4">
<table type="X" address="0xCA080" />
<table type="Y" address="0xCA088" />
</table>
<table name="Base Timing B" address="0xCA118">
<table type="X" address="0xCA094" />
<table type="Y" address="0xCA0D0" />
</table>
<table name="Base Timing Alternate (Coolant Temp)" address="0xC951E">
<table type="Y" address="0xC946C" />
</table>
<table name="Timing Advance A (Maximum)" address="0xC9F5C" sizex="15" >
<table type="X" address="0xC9ED8" />
<table type="Y" address="0xC9F14"/>
</table>
<table name="Timing Advance B (Maximum)" address="0xCA07C" sizex="2" sizey="2" userlevel="4">
<table type="X" address="0xCA06C" />
<table type="Y" address="0xCA074" />
</table>
<table name="Intake Cam Advance Angle A (AVCS)" address="0xCDB84" sizex="2" sizey="2" userlevel="4">
<table type="X" address="0xCDB74" />
<table type="Y" address="0xCDB7C" />
</table>
<table name="Intake Cam Advance Angle B (AVCS)" address="0xCDC08" sizex="15" sizey="16" >
<table type="X" address="0xCDB8C" />
<table type="Y" address="0xCDBC8" />
</table>
<table name="Advance Multiplier (Initial)" address="0xC91CC"/>
<table name="Advance Multiplier (Boost Control)" address="0xC06C8" />
<table name="Advance Multiplier (Fuel Map Switch)" address="0xC60E8" />
<table name="Timing Compensation A (Intake Temp)" address="0xC9694">
<table type="Y" address="0xC9654" />
</table>
<table name="Timing Compensation A (Intake Temp) Activation" address="0xCA268">
<table type="X" address="0xCA228" />
<table type="Y" address="0xCA248" />
</table>
<table name="Timing Compensation B (Intake Temp)" address="0xC9984">
<table type="Y" address="0xC9944" />
</table>
<table name="Timing Compensation (Coolant Temp)" address="0xC9641">
</table>
<table name="Feedback Correction Range (RPM)" address="0xC9188" />
<table name="Rough Correction Range (RPM)" address="0xC91A8" />
<table name="Rough Correction Range (Load)" address="0xC91B8" />
<table name="Fine Correction Minimum (RPM)" address="0xC9118" />
<table name="Fine Correction Maximum (RPM)" address="0xC9238" />
<table name="Fine Correction Range (Load)" address="0xC9240" />
<table name="Fine Correction Rows (RPM)" address="0xC9208" />
<table name="Fine Correction Columns (Load)" address="0xC91F8" />
<table name="Fine Correction Advance Step Value" address="0xC922C"/>
<table name="MAF Sensor Scaling" address="0xCC15C" sizey="48" >
<table type="Y" address="0xCC09C" />
</table>
<table name="MAF Limit (Maximum)" address="0xC0F44" />
<table name="Rev Limit" address="0xC6300" />
<table name="Speed Limiting A" address="0xC6350" />
<table name="Speed Limiting B" address="0xC635C" />
<table name="Speed Limiting C" address="0xDB83C" />
<table name="Throttle Actuator Duty" address="0xDC234">
<table type="X" address="0xDC1B4" />
<table type="Y" address="0xDC1F0" />
</table>
<table name="Idle Speed A (Coolant Temp)" address="0xCAE08" >
<table type="Y" address="0xCAA2C" />
</table>
<table name="Idle Speed B (Coolant Temp)" address="0xCAE48" >
</table>
<table name="Idle Speed C (Coolant Temp)" address="0xCAE88" >
</table>
<table name="Closed Loop Delays" address="0xC5D3E" sizey="2" />
<table name="Closed Loop Coolant Temp" address="0xC60F8" />
<table name="Closed Loop Vehicle Speed" address="0xC6170" />
<table name="Closed Loop Calculated Load" address="0xC7074" >
<table type="Y" address="0xC7034" />
</table>
<table name="Closed Loop RPM (Per Gear)" address="0xC60FC" />
<table name="Closed Loop RPM (Other)" address="0xC614C" />
<table name="Closed Loop Throttle (Primary)" address="0xC67E0">
<table type="Y" address="0xC67A0" />
</table>
<table name="Closed Loop Throttle Maximum" address="0xC616C" />
<table name="MAF Compensation (Intake Temp)" address="0xC18A8">
<table type="X" address="0xC1874" />
<table type="Y" address="0xC1888" />
</table>
<table name="Engine Load Compensation (MP)" address="0xC1938">
<table type="X" address="0xC18D0" />
<table type="Y" address="0xC18FC" />
</table>
<table name="Engine Load Limit (Maximum)" address="0x1B83C" />
<table name="Manifold Pressure Sensor Scaling" address="0xC028C" />
<table name="Atmospheric Pressure Sensor Scaling" address="0xC0250" />
<table name="TD Activation Thresholds (Target Boost)" address="0xC0678" />
<table name="TD Integral Negative Activation (Boost Error)" address="0xC0684" />
<table name="TD Integral Positive Activation (Boost Error)" address="0xC068C" />
<table name="TD Activation Thresholds (RPM)" address="0xC069C" />
<table name="TD Proportional Compensation (Intake Temp)" address="0xC0730">
<table type="Y" address="0xC0720" />
</table>
<table name="TD Integral Negative Compensation (Intake Temp)" address="0xC0744">
<table type="Y" address="0xC0734" />
</table>
<table name="TD Integral Positive Compensation (Intake Temp)" address="0xC0758">
<table type="Y" address="0xC0748" />
</table>
<table name="TD Integral Cumulative Range (WG Correction)" address="0xC06A4" />
<table name="TD Integral Positive Activation (Wastegate Duty)" address="0xC0690" />
<table name="Wastegate Duty Limit (Maximum)" address="0x17498" />
<table name="Intake Temp Sensor Scaling" address="0x7D31C">
<table type="Y" address="0x7D2A4" />
</table>
<table name="Coolant Temp Sensor Scaling" address="0x7D234">
<table type="Y" address="0x7D1C4" />
</table>
<table name="Fuel Temp Sensor Scaling" address="0xCC024">
<table type="Y" address="0xCBFAC" />
</table>
<table name="Boost Comp Atmosphere Multiplier Determination" address="0xC0990">
<table type="Y" address="0xC0980" />
</table>
<table name="Boost Comp Atmosphere Multiplier Offset" address="0xC08BC">
<table type="Y" address="0xC08AC" />
</table>
<table name="AF Learning #1 Range" address="0xC60BC" />
<table name="Front Oxygen Sensor Scaling" address="0xCC250">
<table type="Y" address="0xCC21C" />
</table>
<table name="Front Oxygen Sensor Compensation (Atmosphere)" address="0xC12D0">
<table type="Y" address="0xC12C0" />
</table>
<table name="Front Oxygen Sensor Rich Limit" address="0x1D7C8" />
<table name="Rev Limit Fuel Resume" address="0xC6308" />
<table name="(P0000) PASS CODE (NO DTC DETECTED)" address="0x6C46B"/>
<table name="(P0000) PASS CODE (NO DTC DETECTED) " address="0x6C46C"/>
<table name="(P0011) CAMSHAFT POS. - TIMING OVER-ADVANCED 1" address="0x6C451"/>
<table name="(P0016) CRANKSHAFT/CAMSHAFT CORRELATION 1A" address="0x6C4D0"/>
<table name="(P0018) CRANKSHAFT/CAMSHAFT CORRELATION 2A" address="0x6C4CF"/>
<table name="(P0021) CAMSHAFT POS. - TIMING OVER-ADVANCED 2" address="0x6C452"/>
<table name="(P0030) FRONT O2 SENSOR RANGE/PERF" address="0x6C490"/>
<table name="(P0031) FRONT O2 SENSOR LOW INPUT" address="0x6C477"/>
<table name="(P0032) FRONT O2 SENSOR HIGH INPUT" address="0x6C475"/>
<table name="(P0037) REAR O2 SENSOR LOW INPUT" address="0x6C476"/>
<table name="(P0038) REAR O2 SENSOR HIGH INPUT" address="0x6C474"/>
<table name="(P0068) MAP SENSOR RANGE/PERF" address="0x6C48C"/>
<table name="(P0101) MAF SENSOR RANGE/PERF" address="0x6C48E"/>
<table name="(P0102) MAF SENSOR LOW INPUT" address="0x6C42D"/>
<table name="(P0103) MAF SENSOR HIGH INPUT" address="0x6C42E"/>
<table name="(P0107) MAP SENSOR LOW INPUT" address="0x6C478"/>
<table name="(P0108) MAP SENSOR HIGH INPUT" address="0x6C479"/>
<table name="(P0111) IAT SENSOR RANGE/PERF" address="0x6C473"/>
<table name="(P0112) IAT SENSOR LOW INPUT" address="0x6C471"/>
<table name="(P0113) IAT SENSOR HIGH INPUT" address="0x6C472"/>
<table name="(P0117) COOLANT TEMP SENSOR LOW INPUT" address="0x6C435"/>
<table name="(P0118) COOLANT TEMP SENSOR HIGH INPUT" address="0x6C436"/>
<table name="(P0121) TPS RANGE/PERF" address="0x6C434"/>
<table name="(P0122) TPS A LOW INPUT" address="0x6C432"/>
<table name="(P0123) TPS A HIGH INPUT" address="0x6C433"/>
<table name="(P0125) INSUFFICIENT COOLANT TEMP (FUELING)" address="0x6C438"/>
<table name="(P0126) INSUFFICIENT COOLANT TEMP (OPERATION)" address="0x6C4B9"/>
<table name="(P0128) THERMOSTAT MALFUNCTION" address="0x6C47A"/>
<table name="(P0131) FRONT O2 SENSOR LOW INPUT" address="0x6C46E"/>
<table name="(P0132) FRONT O2 SENSOR HIGH INPUT" address="0x6C46F"/>
<table name="(P0133) FRONT O2 SENSOR SLOW RESPONSE" address="0x6C45C"/>
<table name="(P0134) FRONT O2 SENSOR NO ACTIVITY" address="0x6C48F"/>
<table name="(P0137) REAR O2 SENSOR LOW VOLTAGE" address="0x6C46D"/>
<table name="(P0138) REAR O2 SENSOR HIGH VOLTAGE" address="0x6C470"/>
<table name="(P0139) REAR O2 SENSOR SLOW RESPONSE" address="0x6C45D"/>
<table name="(P0140) REAR O2 SENSOR NO ACTIVITY" address="0x6C4CC"/>
<table name="(P0171) SYSTEM TOO LEAN" address="0x6C463"/>
<table name="(P0172) SYSTEM TOO RICH" address="0x6C464"/>
<table name="(P0181) FUEL TEMP SENSOR A RANGE/PERF" address="0x6C445"/>
<table name="(P0182) FUEL TEMP SENSOR A LOW INPUT" address="0x6C443"/>
<table name="(P0183) FUEL TEMP SENSOR A HIGH INPUT" address="0x6C444"/>
<table name="(P0222) TPS B LOW INPUT" address="0x6C493"/>
<table name="(P0223) TPS B HIGH INPUT" address="0x6C494"/>
<table name="(P0230) FUEL PUMP PRIMARY CIRCUIT" address="0x6C48B"/>
<table name="(P0244) WASTEGATE SOLENOID A RANGE/PERF" address="0x6C481"/>
<table name="(P0245) WASTEGATE SOLENOID A LOW" address="0x6C47F"/>
<table name="(P0246) WASTEGATE SOLENOID A HIGH" address="0x6C480"/>
<table name="(P0261) FUEL INJECTOR #1 CIRCUIT LOW" address="0x6C482"/>
<table name="(P0264) FUEL INJECTOR #2 CIRCUIT LOW" address="0x6C483"/>
<table name="(P0267) FUEL INJECTOR #3 CIRCUIT LOW" address="0x6C484"/>
<table name="(P0270) FUEL INJECTOR #4 CIRCUIT LOW" address="0x6C485"/>
<table name="(P0301) MISFIRE CYLINDER 1" address="0x6C465"/>
<table name="(P0302) MISFIRE CYLINDER 2" address="0x6C466"/>
<table name="(P0303) MISFIRE CYLINDER 3" address="0x6C467"/>
<table name="(P0304) MISFIRE CYLINDER 4" address="0x6C468"/>
<table name="(P0327) KNOCK SENSOR 1 LOW INPUT" address="0x6C430"/>
<table name="(P0328) KNOCK SENSOR 1 HIGH INPUT" address="0x6C431"/>
<table name="(P0335) CRANKSHAFT POS. SENSOR A MALFUNCTION" address="0x6C428"/>
<table name="(P0336) CRANKSHAFT POS. SENSOR A RANGE/PERF" address="0x6C429"/>
<table name="(P0340) CAMSHAFT POS. SENSOR A MALFUNCTION" address="0x6C42B"/>
<table name="(P0340) CAMSHAFT POS. SENSOR A MALFUNCTION " address="0x6C4A7"/>
<table name="(P0341) CAMSHAFT POS. SENSOR A RANGE/PERF" address="0x6C42A"/>
<table name="(P0345) CAMSHAFT POS. SENSOR A BANK 2" address="0x6C4A6"/>
<table name="(P0350) IGNITION COIL PRIMARY/SECONDARY" address="0x6C43C"/>
<table name="(P0365) CAMSHAFT POS. SENSOR B BANK 1" address="0x6C44F"/>
<table name="(P0365) CAMSHAFT POS. SENSOR B BANK 1 " address="0x6C4A5"/>
<table name="(P0390) CAMSHAFT POS. SENSOR B BANK 2" address="0x6C450"/>
<table name="(P0390) CAMSHAFT POS. SENSOR B BANK 2 " address="0x6C4A4"/>
<table name="(P0410) SECONDARY AIR PUMP SYSTEM" address="0x6C4C6"/>
<table name="(P0411) SECONDARY AIR PUMP INCORRECT FLOW" address="0x6C4C5"/>
<table name="(P0413) SECONDARY AIR PUMP A OPEN" address="0x6C4CA"/>
<table name="(P0414) SECONDARY AIR PUMP A SHORTED" address="0x6C4CD"/>
<table name="(P0416) SECONDARY AIR PUMP B OPEN" address="0x6C4D7"/>
<table name="(P0417) SECONDARY AIR PUMP B SHORTED" address="0x6C4D6"/>
<table name="(P0418) SECONDARY AIR PUMP RELAY A" address="0x6C4CB"/>
<table name="(P0420) CAT EFFICIENCY BELOW THRESHOLD" address="0x6C460"/>
<table name="(P0442) EVAP LEAK DETECTED (SMALL)" address="0x6C461"/>
<table name="(P0447) EVAP VENT CONTROL CIRCUIT OPEN" address="0x6C45A"/>
<table name="(P0448) EVAP VENT CONTROL CIRCUIT SHORTED" address="0x6C45B"/>
<table name="(P0451) EVAP PRESSURE SENSOR RANGE/PERF" address="0x6C441"/>
<table name="(P0452) EVAP PRESSURE SENSOR LOW INPUT" address="0x6C43F"/>
<table name="(P0453) EVAP PRESSURE SENSOR HIGH INPUT" address="0x6C440"/>
<table name="(P0456) EVAP LEAK DETECTED (VERY SMALL)" address="0x6C462"/>
<table name="(P0457) EVAP LEAK DETECTED (FUEL CAP)" address="0x6C46A"/>
<table name="(P0458) EVAP PURGE VALVE CIRCUIT LOW" address="0x6C455"/>
<table name="(P0459) EVAP PURGE VALVE CIRCUIT HIGH" address="0x6C456"/>
<table name="(P0461) FUEL LEVEL SENSOR RANGE/PERF" address="0x6C43B"/>
<table name="(P0462) FUEL LEVEL SENSOR LOW INPUT" address="0x6C439"/>
<table name="(P0463) FUEL LEVEL SENSOR HIGH INPUT" address="0x6C43A"/>
<table name="(P0464) FUEL LEVEL SENSOR INTERMITTENT" address="0x6C437"/>
<table name="(P0483) RADIATOR FAN RATIONALITY CHECK" address="0x6C44D"/>
<table name="(P0500) VEHICLE SPEED SENSOR A" address="0x6C42F"/>
<table name="(P0502) VEHICLE SPEED SENSOR LOW INPUT" address="0x6C48A"/>
<table name="(P0503) VEHICLE SPEED SENSOR INTERMITTENT" address="0x6C491"/>
<table name="(P0506) IDLE CONTROL RPM LOWER THAN EXPECTED" address="0x6C449"/>
<table name="(P0507) IDLE CONTROL RPM HIGH THAN EXPECTED" address="0x6C44A"/>
<table name="(P0508) IDLE CONTROL CIRCUIT LOW" address="0x6C447"/>
<table name="(P0509) IDLE CONTROL CIRCUIT HIGH" address="0x6C448"/>
<table name="(P0512) STARTER REQUEST CIRCUIT" address="0x6C43E"/>
<table name="(P0519) IDLE CONTROL MALFUNCTION (FAIL-SAFE)" address="0x6C48D"/>
<table name="(P0545) EGT SENSOR CIRCUIT LOW" address="0x6C486"/>
<table name="(P0546) EGT SENSOR CIRCUIT HIGH" address="0x6C487"/>
<table name="(P0562) SYSTEM VOLTAGE LOW" address="0x6C47D"/>
<table name="(P0563) SYSTEM VOLTAGE HIGH" address="0x6C47E"/>
<table name="(P0600) SERIAL COMMUNICATION LINK" address="0x6C4A3"/>
<table name="(P0604) CONTROL MODULE RAM ERROR" address="0x6C42C"/>
<table name="(P0605) CONTROL MODULE ROM ERROR" address="0x6C4A8"/>
<table name="(P0607) CONTROL MODULE PERFORMANCE" address="0x6C49B"/>
<table name="(P0638) THROTTLE ACTUATOR RANGE/PERF" address="0x6C49A"/>
<table name="(P0691) RADIATOR FAN CIRCUIT LOW" address="0x6C44B"/>
<table name="(P0692) RADIATOR FAN CIRCUIT HIGH" address="0x6C44C"/>
<table name="(P0700) TRANSMISSION CONTROL SYSTEM" address="0x6C4B1"/>
<table name="(P0851) NEUTRAL SWITCH INPUT LOW" address="0x6C442"/>
<table name="(P0852) NEUTRAL SWITCH INPUT HIGH" address="0x6C446"/>
<table name="(P0864) TCM COMMUNICATION RANGE/PERF" address="0x6C44E"/>
<table name="(P0865) TCM COMMUNICATION CIRCUIT LOW" address="0x6C457"/>
<table name="(P0866) TCM COMMUNICATION CIRCUIT HIGH" address="0x6C458"/>
<table name="(P1152) FRONT O2 SENSOR RANGE/PERF LOW B1 S1" address="0x6C45E"/>
<table name="(P1153) FRONT O2 SENSOR RANGE/PERF HIGH B1 S1" address="0x6C45F"/>
<table name="(P1160) ABNORMAL RETURN SPRING" address="0x6C495"/>
<table name="(P1301) MISFIRE (HIGH TEMP EXHAUST GAS)" address="0x6C469"/>
<table name="(P1312) EGT SENSOR MALFUNCTION" address="0x6C488"/>
<table name="(P1400) FUEL TANK PRESSURE SOL. LOW" address="0x6C453"/>
<table name="(P1410) FUEL TANK PRESSURE SYSTEM MALFUNCTION" address="0x6C4D1"/>
<table name="(P1418) FUEL LEVEL SENSOR SIGNAL HIGH" address="0x6C4CE"/>
<table name="(P1420) FUEL TANK PRESSURE SOL. HIGH INPUT" address="0x6C454"/>
<table name="(P1443) VENT CONTROL SOLENOID FUNCTION PROBLEM" address="0x6C459"/>
<table name="(P1491) PCV (BLOWBY) FUNCTION PROBLEM" address="0x6C47B"/>
<table name="(P1518) STARTER SWITCH LOW INPUT" address="0x6C43D"/>
<table name="(P1544) EGT TOO HIGH" address="0x6C489"/>
<table name="(P1560) BACK-UP VOLTAGE MALFUNCTION" address="0x6C47C"/>
<table name="(P2004) TGV - INTAKE MANIFOLD RUNNER 1 STUCK OPEN" address="0x6C4B4"/>
<table name="(P2005) TGV - INTAKE MANIFOLD RUNNER 2 STUCK OPEN" address="0x6C4B6"/>
<table name="(P2006) TGV - INTAKE MANIFOLD RUNNER 1 STUCK CLOSED" address="0x6C4B5"/>
<table name="(P2007) TGV - INTAKE MANIFOLD RUNNER 2 STUCK CLOSED" address="0x6C4B7"/>
<table name="(P2008) TGV - INTAKE MANIFOLD RUNNER 1 CIRCUIT OPEN" address="0x6C4C2"/>
<table name="(P2009) TGV - INTAKE MANIFOLD RUNNER 1 CIRCUIT LOW" address="0x6C4C0"/>
<table name="(P2011) TGV - INTAKE MANIFOLD RUNNER 2 CIRCUIT OPEN" address="0x6C4C3"/>
<table name="(P2012) TGV - INTAKE MANIFOLD RUNNER 2 CIRCUIT LOW" address="0x6C4C1"/>
<table name="(P2016) TGV - INTAKE MANIFOLD RUNNER 1 POS. SENSOR LOW" address="0x6C4BC"/>
<table name="(P2017) TGV - INTAKE MANIFOLD RUNNER 1 POS. SENSOR HIGH" address="0x6C4BD"/>
<table name="(P2021) TGV - INTAKE MANIFOLD RUNNER 2 POS. SENSOR LOW" address="0x6C4BE"/>
<table name="(P2022) TGV - INTAKE MANIFOLD RUNNER 2 POS. SENSOR HIGH" address="0x6C4BF"/>
<table name="(P2088) OCV SOLENOID A1 CIRCUIT OPEN" address="0x6C4B0"/>
<table name="(P2089) OCV SOLENOID A1 CIRCUIT SHORT" address="0x6C4AF"/>
<table name="(P2090) OCV SOLENOID B1 CIRCUIT OPEN" address="0x6C4AC"/>
<table name="(P2091) OCV SOLENOID B1 CIRCUIT SHORT" address="0x6C4AB"/>
<table name="(P2092) OCV SOLENOID A2 CIRCUIT OPEN" address="0x6C4AE"/>
<table name="(P2093) OCV SOLENOID A2 CIRCUIT SHORT" address="0x6C4AD"/>
<table name="(P2094) OCV SOLENOID B2 CIRCUIT OPEN" address="0x6C4AA"/>
<table name="(P2095) OCV SOLENOID B2 CIRCUIT SHORT" address="0x6C4A9"/>
<table name="(P2096) POST CATALYST TOO LEAN B1" address="0x6C499"/>
<table name="(P2097) POST CATALYST TOO RICH B1" address="0x6C4A2"/>
<table name="(P2101) THROTTLE ACTUATOR CIRCUIT RANGE/PERF" address="0x6C498"/>
<table name="(P2102) THROTTLE ACTUATOR CIRCUIT LOW" address="0x6C496"/>
<table name="(P2103) THROTTLE ACTUATOR CIRCUIT HIGH" address="0x6C497"/>
<table name="(P2109) TPS A MINIMUM STOP PERF" address="0x6C492"/>
<table name="(P2122) TPS D CIRCUIT LOW INPUT" address="0x6C49F"/>
<table name="(P2123) TPS D CIRCUIT HIGH INPUT" address="0x6C4A0"/>
<table name="(P2127) TPS E CIRCUIT LOW INPUT" address="0x6C49D"/>
<table name="(P2128) TPS E CIRCUIT HIGH INPUT" address="0x6C49E"/>
<table name="(P2135) TPS A/B VOLTAGE" address="0x6C4A1"/>
<table name="(P2138) TPS D/E VOLTAGE" address="0x6C49C"/>
<table name="(P2227) BARO. PRESSURE CIRCUIT RANGE/PERF" address="0x6C4B8"/>
<table name="(P2228) BARO. PRESSURE CIRCUIT LOW INPUT" address="0x6C4BB"/>
<table name="(P2229) BARO. PRESSURE CIRCUIT HIGH INPUT" address="0x6C4BA"/>
<table name="(P2431) SECONDARY AIR PUMP CIRCUIT RANGE/PERF" address="0x6C4C7"/>
<table name="(P2432) SECONDARY AIR PUMP CIRCUIT LOW" address="0x6C4C9"/>
<table name="(P2433) SECONDARY AIR PUMP CIRCUIT HIGH" address="0x6C4C8"/>
<table name="(P2440) SECONDARY AIR PUMP VALVE 1 STUCK OPEN" address="0x6C4D5"/>
<table name="(P2441) SECONDARY AIR PUMP VALVE 1 STUCK CLOSED" address="0x6C4D4"/>
<table name="(P2442) SECONDARY AIR PUMP VALVE 2 STUCK OPEN" address="0x6C4D3"/>
<table name="(P2443) SECONDARY AIR PUMP 2 STUCK CLOSED" address="0x6C4D2"/>
<table name="(P2444) SECONDARY AIR PUMP 1 STUCK ON B1" address="0x6C4C4"/>
<table name="(P2503) CHARGING SYSTEM VOLTAGE LOW" address="0x6C4B3"/>
<table name="(P2504) CHARGING SYSTEM VOLTAGE HIGH" address="0x6C4B2"/>
</rom>
Please note. IT DOESN'T WORK IN ECUFLASH YET.... :wink:
PostPosted: Sun Jul 01, 2007 8:08 am
by merchgod
That's a waste of time. You don't need to do that for flashing. Use Enginuity for tuning and Ecuflash for flashing.
PostPosted: Mon Jul 02, 2007 12:54 am
by ravenhil
thanks! problem solved! i'll be trying to pull roms off a 1.6L Impreza TS next.
PostPosted: Mon Jul 02, 2007 9:35 am
by hmanxx
merchgod wrote:It doesn't matter whether or not Ecuflash has the maps correctly defined or not. You can flash with Ecuflash without modifying the tables in Ecuflash. You just have to make sure the .xml file corresponding to your cal id (ecuflash\rommetadata directory) has the correct flashmethod tag. It doesn't need to have any table definitions at all. For the 32bit ecus, use sti04 for 512kb rom and sti05 for a 1mb rom.
if Ecuflash has yet to support a new ROM..to flash using ECUFLASH..I just need to add a new xml file bearing the contents something like below should work right
Essential data
<romid>
<xmlid>CAL ID:NEWECUxxx</xmlid>
<internalidstring>NEWECUxxx</internalidstring>
<flashmethod>RelevantFlashmethod</flashmethod>
</romid>
PostPosted: Mon Jul 02, 2007 11:14 am
by merchgod
Should look like this for a 32bit ecu:
<rom>
   <romid>
      <xmlid>NEWECUxx</xmlid>
      <internalidstring>NEWECUxx</internalidstring>
      <flashmethod>sti05 OR sti04</flashmethod>
   </romid>
   <include>sti05base OR sti04base</include>
</rom>
PostPosted: Thu Oct 18, 2007 8:04 am
by ravenhil
Man i wish enginuity has interpolation. I really hate to edit the value a cell at a time
