Want to read ECU only, jumper block needed?
I just want to read what is on the ECU now, currently do not have any interest in writing to the ECU. I bought the tactrix cable and hooked the green test mode connectors together but have been unable to get OpenECU to read the ROM image. Do I have to jumper the other block as well to only read the ECU image? My impression was that the shorting of the other block was only needed if I want to write to the ECU and I wouldn't have to do it if I was just reading from the ECU. USDM '03 WRX.
