Page 1 of 2
cant read ecu to subaru
PostPosted: Wed Jun 20, 2007 6:57 am
by 0xyGen
look it picture please
and help me please
PostPosted: Tue Sep 11, 2007 10:05 am
by missyjo83490
hi , i ve got the same problem , what have you do for it ?
PostPosted: Tue Sep 11, 2007 3:42 pm
by radsdau
Please show us a log of your attempted hook-up.
PostPosted: Wed Sep 12, 2007 3:57 am
by ecu_fix
Have the same issue,
Connect Green Connectors
OBD Cable plugged in
Ign on
Press Read and this comes up:
[14:45:57.406] Using interface OpenPort 1.3 Universal X460m0o6e5bb7c96bbedc06d28fbfc35410af8e303b3a07
[14:46:02.443] SSM2 read ram byte addr: 000061
[14:46:02.493] ECU is in test mode
[14:46:03.574] denso02_bootloader_cmd_start
[14:46:04.796] denso02_bootloader_cmd_start
[14:46:06.018] denso02_bootloader_cmd_start
[14:46:07.240] denso02_bootloader_cmd_start
[14:46:08.461] denso02_bootloader_cmd_s
[14:46:08.461] denso02_bootloader_cmd_start
[14:46:08.882] kernel get version
Then i get a windoes saying there is an error
I always get this same result
Any ideas?
PostPosted: Sun Sep 16, 2007 12:00 pm
by missyjo83490
it s exactly what i have to !! baut i have a ecutek reflash and i think what this probleme is ecutek, it blocked the read ecu ?
it s right ?
have you got ecutek tuning on your car ?
what s the solution ?
PostPosted: Wed Sep 19, 2007 9:12 am
by missyjo83490
anyone have solution?
PostPosted: Wed Sep 19, 2007 9:31 pm
by ecu_fix
Our car was stock.
PostPosted: Thu Sep 20, 2007 8:01 am
by missyjo83490
no , i ve got a ecutek tuning....sniff !!
PostPosted: Sat Sep 29, 2007 10:27 pm
by Dweeb
So, if you got Ecutek, you can't read the rom image ???
PostPosted: Sun Sep 30, 2007 6:25 am
by ravenhil
Well gee sorry to say this but once your car has ben tuned with Ecutek, its locked out forever. Even "uninstalling" Ecutek will return it to a state where Openecu can access it.
This is one reason why it caused an uproar in Nasoic.
http://forums.nasioc.com/forums/showthr ... ?t=1027462
PostPosted: Sun Sep 30, 2007 6:31 am
by ravenhil
oxygen, I assume that the car you are attempting to flash or read from is
1) Not ECUTEK-ed
2) A supported model that openecu can access
3) has been installed with the necessary jumpers, if at all
Once these are done, you have to
1) Ensure that the green connectors are well connected
2) Turn the ignition key but do not crank start, you should see a flashing CEL and the radiator fan will go on and off, on and off...
3) Switch off the ignition totally
4) Select the proper metadata on Ecuflash
5) Only turn the ignition to "ON" when PROMPTED by the program
6) It should work...
I used to skip step 5 and and left the ignition at the "ON" position. Apparently, it won't work that way.
PostPosted: Sun Sep 30, 2007 4:07 pm
by Dweeb
I am having the same issue, here is my ECU:
JDM STI 7 RA Type C 01/02 - ag970 3391
ECU ID: 29044A4105
(sticker on the actual ECU box)
3E
22011AG970
112200-3391
12V
*223391K
when i use ecuflash, i get:
[17:14:21.351] Version 1.32.1399
[17:14:21.361] 11 memory models read.
[17:14:21.361] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:14:21.651] 218 ROM metadata models scanned.
[17:14:21.651] checksum module "subarudbw" loaded.
[17:14:21.661] flashing tool "wrx02" loaded.
[17:14:21.661] flashing tool "wrx04" loaded.
[17:14:21.661] flashing tool "sti04" loaded.
[17:14:21.661] flashing tool "sti05" loaded.
[17:14:21.661] flashing tool "mitsukernel" loaded.
[17:14:21.661] flashing tool "mitsukernelocp" loaded.
[17:14:21.661] flashing tool "shbootmode" loaded.
[17:14:33.148] Using interface OpenPort 1.3 Subaru TX46qpWr2b8637d5b362fbac788936dda0ee94216b6db90b
[17:14:34.911] SSM2 read ram byte addr: 000061
[17:14:34.961] ECU is in test mode
[17:14:36.012] denso02_bootloader_cmd_start
[17:14:37.244] denso02_bootloader_cmd_start
[17:14:38.476] denso02_bootloader_cmd_start
[17:14:39.697] denso02_bootloader_cmd_start
[17:14:40.929] denso02_bootloader_cmd_start
[17:14:41.380] kernel get version
i have been flashed with EcuTeK v2.x in Nov. last year.
is there a way to get in into my ecu ???
PostPosted: Sun Sep 30, 2007 7:00 pm
by Dweeb
forgot to mention when i try to do get my ROM image, in the above log i get the Ecuflash error after this line:
then i get window popup saying
"an error occurred. See the log for details"
in the popup window
PostPosted: Tue Apr 22, 2008 11:31 am
by jukka
I have a edm sti 04. It's ecutek tuned, and I can't do anything to it. I'v been planning to get a fresh ecu to it and sell the old ecu with the ecutek license.
Is there a list of ecus that are comparable with my old ecu? Can I use, mayby JDM 01->04 ecu?
PostPosted: Tue Apr 22, 2008 3:46 pm
by LOK11
Hi All,
We should be able to assist you. Tactrix may do this as well, or maybe only to recover from a partial flash fail. You may wish to see http://forums.openecu.org/viewtopic.php ... ght=#16865 for previous discussion of unlocking any Subaru or EVO ECUtek'd ECUs. Send them across if you need them done.
Kind Regards
Lachlan Riddel
Technical Director
ChipTorque
