cant read ecu to subaru
Postby 0xyGen » Wed Jun 20, 2007 6:57 am
look it picture please
and help me please
0xyGen
Postby missyjo83490 » Tue Sep 11, 2007 10:05 am
hi , i ve got the same problem , what have you do for it ?
missyjo83490
Postby radsdau » Tue Sep 11, 2007 3:42 pm
Please show us a log of your attempted hook-up.
Postby ecu_fix » Wed Sep 12, 2007 3:57 am
Have the same issue,
Connect Green Connectors
OBD Cable plugged in
Ign on
Press Read and this comes up:
[14:45:57.406] Using interface OpenPort 1.3 Universal X460m0o6e5bb7c96bbedc06d28fbfc35410af8e303b3a07
[14:46:02.443] SSM2 read ram byte addr: 000061
[14:46:02.493] ECU is in test mode
[14:46:03.574] denso02_bootloader_cmd_start
[14:46:04.796] denso02_bootloader_cmd_start
[14:46:06.018] denso02_bootloader_cmd_start
[14:46:07.240] denso02_bootloader_cmd_start
[14:46:08.461] denso02_bootloader_cmd_s
[14:46:08.461] denso02_bootloader_cmd_start
[14:46:08.882] kernel get version
Then i get a windoes saying there is an error
I always get this same result
Any ideas?
ecu_fix
Postby missyjo83490 » Sun Sep 16, 2007 12:00 pm
it s exactly what i have to !! baut i have a ecutek reflash and i think what this probleme is ecutek, it blocked the read ecu ?
it s right ?
have you got ecutek tuning on your car ?
what s the solution ?
missyjo83490
Postby missyjo83490 » Wed Sep 19, 2007 9:12 am
anyone have solution?
missyjo83490
Postby ecu_fix » Wed Sep 19, 2007 9:31 pm
Our car was stock.
ecu_fix
Postby missyjo83490 » Thu Sep 20, 2007 8:01 am
no , i ve got a ecutek tuning....sniff !!
missyjo83490
Postby Dweeb » Sat Sep 29, 2007 10:27 pm
So, if you got Ecutek, you can't read the rom image ???
Dweeb
Postby ravenhil » Sun Sep 30, 2007 6:25 am
Well gee sorry to say this but once your car has ben tuned with Ecutek, its locked out forever. Even "uninstalling" Ecutek will return it to a state where Openecu can access it.
This is one reason why it caused an uproar in Nasoic.
http://forums.nasioc.com/forums/showthr ... ?t=1027462
ravenhil
Postby ravenhil » Sun Sep 30, 2007 6:31 am
oxygen, I assume that the car you are attempting to flash or read from is
1) Not ECUTEK-ed
2) A supported model that openecu can access
3) has been installed with the necessary jumpers, if at all
Once these are done, you have to
1) Ensure that the green connectors are well connected
2) Turn the ignition key but do not crank start, you should see a flashing CEL and the radiator fan will go on and off, on and off...
3) Switch off the ignition totally
4) Select the proper metadata on Ecuflash
5) Only turn the ignition to "ON" when PROMPTED by the program
6) It should work...
I used to skip step 5 and and left the ignition at the "ON" position. Apparently, it won't work that way.
ravenhil
Postby Dweeb » Sun Sep 30, 2007 4:07 pm
I am having the same issue, here is my ECU:
JDM STI 7 RA Type C 01/02 - ag970 3391
ECU ID: 29044A4105
(sticker on the actual ECU box)
3E
22011AG970
112200-3391
12V
*223391K
when i use ecuflash, i get:
[17:14:21.351] Version 1.32.1399
[17:14:21.361] 11 memory models read.
[17:14:21.361] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:14:21.651] 218 ROM metadata models scanned.
[17:14:21.651] checksum module "subarudbw" loaded.
[17:14:21.661] flashing tool "wrx02" loaded.
[17:14:21.661] flashing tool "wrx04" loaded.
[17:14:21.661] flashing tool "sti04" loaded.
[17:14:21.661] flashing tool "sti05" loaded.
[17:14:21.661] flashing tool "mitsukernel" loaded.
[17:14:21.661] flashing tool "mitsukernelocp" loaded.
[17:14:21.661] flashing tool "shbootmode" loaded.
[17:14:33.148] Using interface OpenPort 1.3 Subaru TX46qpWr2b8637d5b362fbac788936dda0ee94216b6db90b
[17:14:34.911] SSM2 read ram byte addr: 000061
[17:14:34.961] ECU is in test mode
[17:14:36.012] denso02_bootloader_cmd_start
[17:14:37.244] denso02_bootloader_cmd_start
[17:14:38.476] denso02_bootloader_cmd_start
[17:14:39.697] denso02_bootloader_cmd_start
[17:14:40.929] denso02_bootloader_cmd_start
[17:14:41.380] kernel get version
i have been flashed with EcuTeK v2.x in Nov. last year.
is there a way to get in into my ecu ???
Dweeb
Postby Dweeb » Sun Sep 30, 2007 7:00 pm
forgot to mention when i try to do get my ROM image, in the above log i get the Ecuflash error after this line:
then i get window popup saying
"an error occurred. See the log for details"
in the popup window
Dweeb
Postby jukka » Tue Apr 22, 2008 11:31 am
I have a edm sti 04. It's ecutek tuned, and I can't do anything to it. I'v been planning to get a fresh ecu to it and sell the old ecu with the ecutek license.
Is there a list of ecus that are comparable with my old ecu? Can I use, mayby JDM 01->04 ecu?
jukka
Postby LOK11 » Tue Apr 22, 2008 3:46 pm
Hi All,
We should be able to assist you. Tactrix may do this as well, or maybe only to recover from a partial flash fail. You may wish to see http://forums.openecu.org/viewtopic.php ... ght=#16865 for previous discussion of unlocking any Subaru or EVO ECUtek'd ECUs. Send them across if you need them done.
Kind Regards
Lachlan Riddel
Technical Director
ChipTorque
LOK11
