question about sti cable
Postby edysdyno » Sat Jun 09, 2007 9:16 pm
I tunned mitsus but my question is that If with the mitsu cable I can reflash the sti's ? if someone can help me I will apreciate...
thanks in advance.
edy
edysdyno
Postby japerformance » Wed Jun 13, 2007 5:12 am
only if it is the universal cable , if you dotn have the specific scooby cable then you wont be able to unless you have the universal one. when did you buy it and where did you buy it from.
japerformance
Postby edysdyno » Wed Jun 13, 2007 6:48 am
I got it at tactrix and it was like a year ago..... but It is the mitsubishi cable not the universal one.....
edysdyno
Postby Jon [in CT] » Wed Jun 13, 2007 8:30 am
You probably have the 1.3M cable. That cable can be used to reflash Subarus with 32-bit ECUs. It won't be able to reflash the 16-bit ECUs. So you could use it to reflash 2006-7 European STIs and WRXs, but not earlier versions. It will also be able to reflash 2003-6 European Forester XTs.
