Why does ecuflash suck so bad on evo9's?
The deff files are so very very incomplete and haven't shown any improvement in months. They don't work properly with the unknown maps on the ecu.
For example: when adding boost to an evo 9 you get serious issues.
1. Knock retard FOR NO REASON. There is no possible way whatsoever that the car is knocking and it still pulls timing. So, I increase the MAF size and it stops pulling timing. This only works for a few extra psi.
Maybe an overactive knock sensor. Subarus had that for a long time. Maybe this car does too. However, adjusting the knock filters does absolutely nothing. Unlplug knock sensor? Same thing.
My conclusion, THERE IS SO MUCH MISSING from the ecu defs that the evo9's are practically not safely open source tunable for more than say 60hp. Sure you could do more, but you have to lie to the ECU and bypass safety features.
Subaru has implemented a "Desired Torque" map. When you exceed the desired torque it cuts Wastegate Duty Cycle. On the LGT's its 30.2%. So in order to properly tune those bastards you need to get that map or add your own boost controller.
My guess is that mitsu has a similar map. That instead of cutting wastegate duty cycle, it cuts timing.
Can ANYONE look into this? I am at the end of my resources. I can give EVO9 ROMS out the yin yang if they are needed for evaluation.
I am one of the larger monetary contributors to the enginuity program and I'd be willing to contribute monetary to ecuflash as well if it helps make results.
