Refleshing Outlander 2.0T
Postby Morfeus » Sun Mar 18, 2007 1:23 pm
Hi,
I met Outlander 2.0T with that white connector.
Two pins are metallized only!!!
I had no chance to see ECU and have no info about processor now.
Is there solution for reflashing that car?
May be can somebody help with info about processor.
I've seen http://forums.openecu.org/viewtopic.php?t=759&start=0
may be (or may be not) about this subject and I want to know:
1.) Is this MH8202F?
2.) Is there the tool for fleshing this proc.
3.) With what processor MH8202F is compatible (MH8206, MH8305F, 7202)?
Thanx in advance.
_______________________
m.o.r.f.e.u.s_@hotmail.com
OutLander 2.0T white connector
OutLander 2.0T connector.jpg (6.8 KiB) Viewed 3935 times
Morfeus
Postby national12345 » Wed Aug 29, 2007 10:33 pm
brother im not sure bout outlander
but im using ecuflash for my airtrek turbo which has the similar port as the 1 u posted
the cable we get is for evo so need to customise a bit to fit the port..
juz my 2 cents...
national12345
Postby Morfeus » Thu Aug 30, 2007 10:53 am
Thenx,
But do you know something about this port customising?
I would be very thenkful for any info.
national12345 wrote:brother im not sure bout outlander
juz my 2 cents...
Morfeus
Tatrix cable customize for Outlander
Postby FQ-Airtrek » Wed Sep 05, 2007 5:49 pm
Hey bro...
- Locate the thinner cable that also connect to the OBD connector
- Push out the (thin cable) PIN using a small screw driver/clipper
- Use a plyer to squeeze the PIN into a needle like shape
- Bend down (use a torch light) and locate the green colour cable that connect to your car white connector. Airtrek green cable is located at the top left side second pin
- Gently push the reshape pin into the hole (where the green is connector)
- Connect the OBD connector
- Fire up ECU Flash
- Use e7/8 or e9 to read the ecu
Note - Keep the tatrix connector in case u want to use for EVOs
FQ-Airtrek
Postby Morfeus » Sun Sep 09, 2007 1:17 am
1000 thenx!!!
I'll try that :shock: :D !!!
Morfeus
Hi morfeus
Postby christian_piasini » Sat Feb 02, 2008 7:48 am
Here some details you ask.
MCU is MH8202
Some pictures of the ecu too.
Bye
outlander 20T_reading.jpg (72.99 KiB) Viewed 3797 times
