Switches to Green Connectors
Postby s2p2 » Thu Mar 15, 2007 4:14 pm
Hey Guys
We all know how much a pain it is when we have to connect the green connectors. I know some people have done this so just wondering, how have you done a connection to the green connectors with a switch?
Interested in looking at the different solutions that all of you have....
P.S : Anyone knows as well where we can get the green connectors?
Thanks Guys!!
s2p2
Postby Freon » Thu Mar 15, 2007 4:49 pm
You just plug the green connector in, and on either side cut the wire and put the switch in.
I haven't bothered since I'm getting good at reaching down and plugging it in, but it should be pretty easy.
Postby s2p2 » Thu Mar 15, 2007 5:02 pm
Freon wrote:You just plug the green connector in, and on either side cut the wire and put the switch in.
I have seen the rexes and yes, that can be done. For my forester, its a freaking short wire and i HAVE to remove the cover below to reach it! Thats the reason i want to have a switch
s2p2
Postby Kosti » Wed Mar 21, 2007 7:07 pm
I too am thinking of putting in some switched, but I've got the nack of plugging the greens and the flash plug :shock:
Still if I can find a funky switch I'll do it..Was looking at some switched from these guys..
http://www.rjselectronics.com/?gclid=CO ... QgodixBXgw
Kosti
Postby qoncept » Thu Mar 22, 2007 6:25 am
The green connectors house simple spade connectors. Just get a male and a female spade connector and wiring in a switch is a plug n play affair.
Postby Freon » Thu Mar 22, 2007 4:31 pm
^ Good idea. You can get all of this at Radio Shack for a few bucks.
Postby ride5000 » Wed Apr 11, 2007 8:04 am
qoncept wrote:The green connectors house simple spade connectors. Just get a male and a female spade connector and wiring in a switch is a plug n play affair.
that's what i did.
then you make up your switch (ie connectors, mounting ,etc) in a much more convenient location, and just plug it in.
ride5000
Postby NeverLies » Wed Apr 11, 2007 10:24 am
Done it the same way ;)
