A4TH000O tables
A4TH000O tables
Postby prana » Fri Mar 09, 2007 3:07 am
Couple of questions in ECUFlash
1. Boost compensation by Gear table, is that disabled because this ECU no longer supports or was the mapping in the XML incomplete ?
2. Closed loop Min Coolant Temp stock is set to 119.4C whereas under normal operating conditions, coolant is approx 85-95C, does this mean it almost never goes into closed loop ? Is this parameter ignored ?
Cheers
prana
