I'm currently remapping my EUDM STI 8 (AH992 ECU type) which has been slightly modified: Garrett GT30 and some other mods.
Of course I'm maxing out the std maf reading which stops at 4.69V for 292g/s. But I'm not maxing out the MAF capability as the max voltage I get is approx 4.94V.
So,based on the 2.5L STIs (they got a 350g/s MAF scale) I've rescaled my MAF.
Everything would be perfect if only it was possible to save values above 300g/s in the map!!
For example, if I say I'll have 342g/s for 4.92, when I save the file, the value saved will be automaticaly modified to 42g!! It removes 300g/s for all values set above 300g/s!!
Could you explain me how I could get rid of this automatic correction which is really getting on my nerves...
Thx a lot for help...
