Evo 8 ECUFlash ROM...Which parameter shows the Boost levels?
Postby allcdsrus » Thu Nov 23, 2006 4:08 pm
Hi,
I am looking for the Paramater within the ECUFlash which shows the level of boost is set to run at...Peaks at etc. I do not want to change these values, just check them.
Thanks in advance
G
allcdsrus
Postby burgers » Thu Dec 07, 2006 2:08 am
Hi
The "Boost desired engine load" along with the "Boost control load offset" and the "Max Wasegate Duty" you should be able to get rid of the stock taper, but increasing the boost usualy need a change or removal pf the restrictor pills in the boost control solinod pipes. Make sure you have suporting mods and run a logger and wideband.
MB
burgers
