Mitsubishi Pajero 3.2 TurboDiesel
Postby Morfeus » Mon Nov 13, 2006 3:20 pm
Hi,
Can somebody tell something about fleshing Mitsubishi Pajero 3.2 TurboDiesel 2006 (system, processor, with/without flesh on the board) ?
Morfeus
Pajero 3.2 DID
Postby staneve » Fri Mar 21, 2008 3:23 am
Hello,
I try to have some information about readind flashing ECU pajero 3.2 DID common rail(2007 and after), ECU is DENSO 275800 type, processor is 64F7058F80. If some one begin to work with this ECU and write an xml file i'm interesting to try.
For your Pajero 2006, It's an electronique control pump, ant turbo pressure is mecanical control, you can find Ralliart ECU but it's very important to change your injector nozzles by Ralliarts parts. The main cost is the set of injector.
staneve
Hi for future details on both ecus
Postby christian_piasini » Fri May 09, 2008 11:57 am
Please take a look at www.checksumm.com
here the link:
http://www.checksumm.com/chiptuning/mit ... index.html
Best regards
Re: Mitsubishi Pajero 3.2 TurboDiesel
Postby borngeek » Tue Jan 17, 2012 4:36 pm
EDIT: oops HELLO. Name is Justin from Sydney, Australia. Just getting into this stuff so been reading a lot. (lurking)
Thought it was time to create an account and get involved :mrgreen:
Bumping this old thread as I cannot access the below site.
Is there a def file and more info for this ECU anywhere? I have the same one outlined above in a 2009 3.2DID Mitsubishi Triton/L200.
//Have a Openport2.0 etc. :wink:
christian_piasini wrote:Please take a look at http://www.checksumm.com
here the link:
Best regards
borngeek
Postby borngeek » Mon Jan 23, 2012 2:34 pm
Thanks for the reply... :D
This is as far as I have gotten. Lots to learn. :oops:
[11:08:32.141] J2534 API Version: 04.04
[11:08:32.141] J2534 DLL Version: 1.00.3210 Nov 22 2010 23:18:50
[11:08:32.141] Device Firmware Version: 1.11.3209
[11:08:32.141] Device Serial Number: TA6xxxxx
[11:08:34.376] -- loading kernel --
[11:08:34.376] -- connecting to kernel --
[11:08:34.376] kernel get version
[11:08:34.704] ECU HW part number : 1860A487
[11:08:34.719] ECU SW part number : 1860A48704
[11:08:34.719] VIN : MMAJRKB809Dxxxxxx
[11:08:34.735] -- unlocking ECU --
[11:08:34.735] starting session...
[11:08:34.735] requesting seed...
[11:08:34.751] sending key...
[11:08:34.751] no key(s) worked - perhaps this ECU has been intentionally locked?
[11:08:34.766] interface close
[11:08:34.782] interface close
borngeek
Postby borngeek » Mon Jan 23, 2012 3:15 pm
Marcello wrote:hum where are you situated ?
Sydney City. (live near Broadway, work in Paddington) :)
borngeek
Postby yamomoto » Tue Apr 03, 2012 10:45 pm
Anybody can help me stock dump Mitsubishi Pajero IV 3.2 DiD 1860A26104
It is this 04 version.
Thank.
yamomoto
Postby yamomoto » Wed Apr 04, 2012 8:41 pm
For me?
I would be grateful.
yamomoto
Postby yamomoto » Thu Apr 12, 2012 1:39 am
I`m only interested in 1860A26104.
I work with any ecu Mitsubishi, Mazda, Ford (and so on) long before OpenPort 2.0 and Piasini tool.
You can ask about it at Christian. :wink:
yamomoto
Postby yamomoto » Tue Oct 30, 2012 1:18 pm
stryaer wrote:... Mitsubishi Pajero 3.2 TurboDiesel 2006?
Yes.
It`s 2009.
yamomoto
