Impreza STi 2004 AH992-5513
PostPosted: Mon Aug 08, 2005 2:54 pm
by FrSTi
European MY2004 STi8, ECU ref. AH992-5513.
(see AH990-5512 post for more details, this ROM is an update version).
PostPosted: Tue Aug 09, 2005 2:35 am
by NeverLies
Note that this rom file is not in expanded format.
To get it back in expanded format, insert some 00 bytes from 20000 to 27FFF (RAM area)
PostPosted: Tue Oct 25, 2005 10:45 am
by cboles
did you have to set ecuflash to "wrx2002" or "wrx2004" to read these ecus?
PostPosted: Tue Oct 25, 2005 11:54 am
by NeverLies
Set it to wrx2002
PostPosted: Thu Oct 27, 2005 2:15 pm
by FrSTi
cboles wrote:did you have to set ecuflash to "wrx2002" or "wrx2004" to read these ecus?
Yep, wrx2002.
Euro STi MY2003 (AH990-5512) and MY2004 (AH992-5513) are SSM2 only.
Euro STi versions switched to SSM2+SSM3 with MY2005 (AJ840).
Euro STi MY2006 (ECU ref. actually unknown, 2.5 USDM spec engine) is to be released in december 05 with SSM3 only... I didn't dump the press car they gave me for a test drive :roll:
PostPosted: Thu Oct 27, 2005 6:23 pm
by cboles
Don't worry - I'll be adding support for the drive by wire cars soon enough... :wink:
Re: Impreza STi 2004 AH992-5513
PostPosted: Thu Jan 25, 2007 11:47 pm
by fastguy76
FrSTi wrote:European MY2004 STi8, ECU ref. AH992-5513.
You tell update version whats difference ?
here my map is AH992-5513 also.
I will install Hks downpipe uppipe and complete carbon ti exhaust. what is needed to change
thanks
PostPosted: Mon Jan 29, 2007 12:54 pm
by FrSTi
The code has been updated between AH990-5512 and AH992992-5513.
Datas seem to be identical, as far as I explored them.
