Q: Reading ECU
PostPosted: Mon Sep 25, 2006 8:40 am
by goixiz
I would like to know if reading the ECU (copying data to computer)
WOuld I need the following
1. Connect the green connectors (under dash)
2. Use the LoopBack Jumper (white MY05)
this is just to read and not to flash
PostPosted: Mon Sep 25, 2006 9:52 am
by disque71
that seems correct
PostPosted: Mon Sep 25, 2006 10:45 am
by Tea cups
You don't typically need the flash block to read, but to write.
And, of course, you need the openport cable.
PostPosted: Mon Sep 25, 2006 12:18 pm
by goixiz
Tea cups wrote:You don't typically need the flash block to read, but to write.
Do i need to connect the green connectors too ? if i dont use the loopback to read
PostPosted: Mon Sep 25, 2006 12:30 pm
by Tea cups
Yes, you need the green connectors connected to read.
to confirm
PostPosted: Mon Sep 25, 2006 5:21 pm
by goixiz
TO CONFIRM:
you do not need the LOOP BACK connector
BUT
you do need to connect the Green connectors to READ the ROM
PostPosted: Mon Sep 25, 2006 5:51 pm
by Tea cups
correct
