EVO Tuning?
PostPosted: Mon Aug 08, 2005 12:09 pm
by calvinc
anybody know if there are other open source initiatives for the Mitsubishi EVO 8?
PostPosted: Mon Aug 08, 2005 12:33 pm
by cboles
I haven't checked, but it would be fun to do one for that car too. I don't have one to develop on though.
PostPosted: Tue Aug 09, 2005 2:31 am
by NeverLies
EVo 5, 6 , 7 and 8 seems to be using the same protocol. I may have an old ECU from a 6 (have to check).
PostPosted: Tue Aug 09, 2005 5:04 am
by calvinc
i have access to an EVO 8. currently tuned with ecutek. keen to get this working on that platform too.
PostPosted: Tue Aug 09, 2005 3:26 pm
by cboles
Any pointers to protocol information that is known so far? ECU CPU? Pinout used on OBD connector for reflashing? I'm doing a minor redesign of the OpenPort, and I'd like to make sure the hardware supports the EVO too.
PostPosted: Tue Aug 09, 2005 3:52 pm
by calvinc
will dig up what i can...
PostPosted: Thu Aug 11, 2005 5:27 am
by NeverLies
CPU seems to be Hitachi H8/539F. Don't have many information on it right now ...
Anyway, on early version it seems there is an ISP connector on the PCB. Need to check on a EVO7 or 8 ecu. Did someone have some pics ?
PostPosted: Thu Aug 11, 2005 8:50 am
by calvinc
took out the EVO 8 ecu. pics in the following folder - www.tari.co.za/images/EVO
dont know if they'll help. ecu seems to be covered in some sort of sealant. cant read numbers off large chip.
first images show the obd port and another white plug under the dash. obd port has pin connectors on 1,4,5,7,8,14,16. the white plug is apparently used during a reflash too, there is only 1 pin in it. not sure where/what it gets connected to.
PostPosted: Thu Aug 11, 2005 9:37 am
by cboles
Thanks Calvin.
The ECU PCB is probably conformally coated to protect from corrosion / shorts, which makes reading numbers off of the ICs somewhat camera proof. Were you able to read what is written on the IC packages, particularly the big one?
PostPosted: Wed Aug 17, 2005 1:56 am
by RussianE39
calvinc wrote:took out the EVO 8 ecu. pics in the following folder - www.tari.co.za/images/EVO
Hi, Calvin, I'm a newbie there, but want to add 2 cents about EVOs.
First of All - there is readily available EVO-.bin reader.
http://kaele.com/~kashima/car/evo/ In JAPANESE!
Second - Sealant can be easily and harmless washed by using just regular gasoline or smthing like it.
PostPosted: Wed Aug 17, 2005 9:06 am
by calvinc
do you mean the hack-job in the picture? software would be easier...
not my car, will get the numbers soon.
PostPosted: Mon Aug 22, 2005 5:18 am
by RussianE39
Calvin, Of course software would be easier, but when you need to write software to download/upload flash via OBD2 it is necessary to got firmware to disassemble etc. That is the only way currently discovered by me to allow this. Also, as you could see, there is not so hack job, coz there is readily available connector on EVO ECU PCB.
PostPosted: Mon Aug 22, 2005 10:37 pm
by calvinc
no offence meant mike. it seems like you have some good knowledge/information to add to the EVO dissasembly.
PostPosted: Thu Jan 26, 2006 11:06 am
by Nemis
Mitsubishi ??? it't time to change the logo?? :D
PostPosted: Thu Jan 26, 2006 2:32 pm
by cboles
Nemis wrote:Mitsubishi ??? it't time to change the logo?? :D
Actually, it is. I should have some Mitsubishi tools out pretty soon along with Subaru DBW ECU reflashing. This is going to be fun! :)
