Evoscan/Mitsulogger on Evo V and VI
Postby cossie1 » Thu Mar 20, 2008 7:53 am
yhpm ;)
cossie1
Postby evoIT » Mon Aug 18, 2008 1:21 pm
would this have any affect for obd2 emissions testings. im tryin to enable my mirage 99(evo 4 swapped & ecu) to use obd2 diagnostic to test emission. went to the emissions test. the man tried connecting to the obd2 but it didnt log. the real question is i know it wont pass emissions but it doesnt even log to test. just keeps running like its trying to connect. now should i try the 1 to 4 connection to see if itll log to test emissions?
my mirage obd2 connections are:
1- light green
4- ground
5- ground
7- orange
9- light blue
12-yellow
16- red w/ black stripe
does pins 9,12 apply to the obd2 testing? how do i change the braud rate to read, test for emissions? this is not for tuning purposes only to test my obd2 for emissions.
evoIT
Postby Jon [in CT] » Mon Aug 18, 2008 3:49 pm
If you also swapped the EVO4 ECU, you're hosed, because I don't think it's OBD-II compliant, which is required in the US for all ECUs 1996 and newer.
Re: Evoscan/Mitsulogger on Evo V and VI
Postby letsteyr » Wed Dec 24, 2008 1:29 am
any one tryed with evoscan 2.6 to reflash an evo V/VI ?
letsteyr
Postby todd-w » Wed Dec 24, 2008 4:08 am
evoscan is a logging diagnostic tool ,if you fit a 7 ecu you can use ecuflash to map it ,,only requires a few ecu pin changes use 90550001ra rom and make a few changes in ecu periphery .
todd-w
