Auto WRX
Postby west_minist » Sat Sep 02, 2006 8:26 pm
Understandable
Postby west_minist » Sat Sep 02, 2006 8:28 pm
Are you still running the utec?
You can either use ecuexplorer or ecuedit.
I pm you.
Tell me something, af all those mods to the tranny, does she still work and feel the same?
How is the active center diff handling wheel slippage?
It would interesting to see how the ecu works on its own.
There is a revision update to the rom you have.
A4SGE01C
2002WRX4EATStock_A4SGE01C_192.hex
(192 KiB) Downloaded 713 times
Postby tjamz » Sat Sep 02, 2006 8:53 pm
Yes, it feels about the same. Takes a little longer (lag type feel) to get into boost on the street, but is more than made up for by being able to launch @ 5000 RPM and 24psi.
I had been using Enginuity in conjunction with UTEC, though I'm not opposed to selling the utec once I become more versed in tuning w/ different programs and reflashing.
I will have to try that revision update, what exactly is the difference between what I had and what is available?
tjamz
Postby west_minist » Sat Sep 02, 2006 8:56 pm
The SOA i have said it took care:
Misfire codes during hot restart with engine
Temp below 158 deg. F
Includes Logic Change #1~4
